Broiler was working went off would not relight
SOURCE: My Kenmore gas oven does not light.
Remove the oven Racks. Remove the oven base plate. Turn the oven on. You can then see the oven ignitor next to the oven burner. If the oven ignitor does not glow a bright orange,replace it. About a $90 part.
SOURCE: Broiler Works/Oven Doesn't
Jrzy, even though you can see the bake igniter glowing, that doesn't mean it's good. Igniters actually get weak (unlike a light bulb that simply burns out). It's hooked up in series to a safety valve (the valve that allows main gas into the oven) which actually reads the amps flowing through the igniter. If the igniter is weak and the amps are too low, the valve won't open up. Replace your igniter and you'll be cookin' with gas again. Tip---> before you unscrew your old igniter, put a little liquid dish soap on the threads for lubrication. This'll ensure it comes out with no problems.
SOURCE: kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
SOURCE: Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
SOURCE: Kenmore 75358 -oven not lighting
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
i can not hear or smell any gas entering oven. also the igniter is not working or clicking
