Even when i use the drain function, I can hear the water in the machine, but alas its not draining out of the machine and hence clothes are soaking wet. Not receiving any error messages.
SOURCE: Washing machine
there is something caught in the hose's going on the filter,or something in the pump,drain water again lay machine down on its side,so you.................................can see what you are doing remove and check all hose's,for sock or the like that,happy Chrismas Ire!!!
SOURCE: Drain pump removal on Zanussi FJR1254 Washing Machine
not easy.suggest you disconnect pump and power up independently as an easy way to check if it runs
easiest way to remove pump - and its awkward - is to undo the 3 screws holding the pump to its housing
SOURCE: zanussi jetsystem 1400 not drainng properly.........
There should be a filter located at bottom front right of washer behind a metal cover.
Press on cover to open, and remove filter by unscrewing anti -clockwise.
Also check outlet pipe is not blocked, more so if it goes into a sink waste connection, if it still leaves water in drum, then there is probably a partial blockage else where, which will require further investigation.
Please leave a fixya rating if my solution solves your problem.
Thankyou.
SOURCE: We went to tumble dry towels but when going back
If you can, lay the drain outlet hose down to floor level, and let the water run into a bucket or similar.
Then check the filter, which should be located at the bottom front right of washer behind drop down flap.
Remove and clean by unscrewing it anti-clockwise.
Hope this helps.
Thanks folks for all your replies, much appreciated!!
Seems that in testing machine with several washes and each time performing extra draining though manual hose, taking it apart and cleaning pipes has done the trick. Must have been small bits of grit that interfered with the pump.
Still dont think it the clothes are as dry as when i first got the machine (1600 spin), but its still good!
Thanks again and Happy Holidays!!
