Jabra BT8010 Wireless Headset Logo
A
Anonymous Posted on Nov 20, 2012
Jabra BT8010 symphony-1-25-0.dfu - Jabra BT8010 Wireless Headset
2 Related Answers
A
Anonymous
  • Posted on Aug 21, 2008
SOURCE: Pairing Jabra bt8010 with a Vista Computer?
What you can do is go to dell's website and dl the bluetooth driver
I read it online
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central
Just go ahead and dl the bluetooth driver at the "network" tabs.
Anonymous
  • Posted on Feb 03, 2011
SOURCE: where to find Jabra BT8010 earhook
Contact the company on website WWW.jabra.com. they are 10.95 plus s/h and you get 5.
I have the same problem as beetank, "my BT8010 Jabra bluetooth is reading Upgrade mode SW ver.:1-33-0 in the window. Does this mean it's junk?
No, it means you are being advised to upgrade the firmware in the BT8010 to the latest version to have improved function. It does not mean your BT8010 won't work, it just won't be a versatile as if you did the upgrade. You will need the follow Jabra's instructions how to download the firmware from their internet site and install it,
Can't find anywhere the bt8010 software
Bluetooth headset hbh-iv840 sony ericsson doesn't work with my ipone4s to lisen to music, can someone help?, plssssssss :)
I need a set of new earhooks for Jabra BT8010 can't find wher to buy. I stay in Moldova, can go to Bucharest, ROmania. have aquaitances in Bilbao and Paris - they could pick it up there could you please...
If price is not an issue and you don't mind the outrageous shipping charge, Jabra sells a pack of 5 from their own website.
http://www.buyjabra.com/accessories/earhook-5-pcs-for-bt125-bt135-17.html#
Forgot passkey
passkey or PIN = 0000 (4 zeros).
If you need the manual you can get it on the link below.
http://adcombhs.com/shopsite_sc/store/html/Jabra_BT8010_Manual.pdf
Good Luck and please rate 4 thumbs up for the free answer.
2helpful
Where to find Jabra BT8010 earhook
3answers
Jabra BT8010 doesn't power up
Contact me if you are interested to sell it for parts acidx0 ~(at)~ gmail.com
4helpful
2answers
Trouble after installing firmware
I had the same problem before I even upgraded the firmware, it showed up after I selected "delete all" in the paired devices menu. I upgraded my firmware to try to the problem but it didn't help but I did come up with a fix thats worked twice for me. so heres the fix i use  1. delete the pairing on your mobile phone.  2. switch on the headset then hold the on switch in the pairing position for about 7 sec. which should put it in pairing mode.  3. do a search with your mobile phone for a new device and it should show your headset 4. pair with it like normal
after pairing my headset's display always comes back on and then operates like normal  hope that helps
I read it online
4answers
English instruction manual
you need to charge the head-set fully and then.... disconect it from power supply. hold down the call button until a continus light appears. and then flip out the speaker tusk.... then search for the device on your phone a couple of times.... if you dont find your headset then your phone is not compatible with the head-set....
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
