Question about Troy-Bilt Super Tomahawk Chipper Shredder Parts Manual 5hp 8hp Garden Way
47259 super tomahawk chipper manual
Trying to find a owners manual and a parts manual for super tomahawk wood chipper. do not know what year.
    Top Expert:
  • Troy-Bilt Master
  • 6,360 Answers
Best Manuals You couldn't ask for a better place!
Posted on Nov 14, 2017
SOURCE:
SOURCE: I don't have a manual for the tomahawk chipper and
You will need to turn the flails (also called cylinder hammers).  Each flail has  4 sharp corner cutouts, only one of which is in use.  When you turn them you get to use a fresh corner, the dull one is still there but no longer contacts the stuff you are chipping.  You will need to remove the chute to access the flywheel, and by rotating the flywheel access the steel bars (cylinder pins) that hold the flails and spacers.  I lay the chipper down, with a 5 gallon bucket protecting the engine, gas tank, to access the bottom, so that you can, using a punch, drive out the 3/16X3/4 roll pin which can be found in one of the long spacers.  You will note each bar has 4 flails, with two long spacers and two short spacers and the roll pin goes through one of the long spacers.  You buy the roll pin punch at a hardware store.   There are four sets of bars with spacers and flails, so four roll pins.  You will want four fresh roll pins also, because the old ones are compressed and shouldn't be used again.  When you have punched out the roll pin you can then drive the bar from the end (where the chute was) but be sure to line the other end of the bar up with the hole on the other sidewall of the chipping compartment.   When you are trying to punch out the roll pin it helps to stabilize the fly wheel--I use a couple of vise grips in a way that the fly wheel is stable.  When you are pounding out the bar (called a cylinder pin) you will need a slightly lesser diameter long (6-8") bolt as a driver.  You can pound on it and it will follow the cylinder pin as it gets pushed out the other side.   When the spacers and flails fall out onto the floor, then you can turn the flails to use a fresh cutting corner and put the spacers and flails back on.  I find it helpful to file the rough edges of the inside ends of the spacers so they slide easily on the cylinder pins.  Get a round file for this purpose.  Also, keep some WD 40 on hand because these things tend to be stuck.  I do only one cylinder pin (with its four flails and four spacers) at a time, so I correctly put it all back in the right order.   You will see that the the order alternates.)
Posted on Mar 23, 2009
Tnsiouxfalls
  • 617 Answers
SOURCE: I just purchased a used Troy built Tomahawk model
http://www.partsandservice.com/html/TroyBilt/cs/cs15016.html
and
http://www.partsandservice.com/bin/ipl.cgi
is all I could find,They're only parts breakdowns.
Posted on Jan 02, 2010
  • 8404 Answers
SOURCE: Have a Troy Bilt chipper/shreader model 47285. I
Taked the broken belt to the auto parts store for a replacement.
Posted on Jun 06, 2010
kel1guy2002
  • 3740 Answers
SOURCE: need replacement chipper blades for 5HP tomahawk
This is the only source that I know of for the older chipper blades. Problem is you need to know the dimensions.
http://www.wesspur.com/chipper-knives/chipper-knives.html
There is an MTD one that is for troy-bilt but was not able to match it up with your unit due to pub issues here on my end: PN is MTD 1901782MA
I recommend you contact these folks to get it sorted out:
http://www.wesspur.com/contact-wesspur.html
Hope this got you pointed in the right direction.
Thanks for using FixYa.
Kelly
Posted on Jun 26, 2010
Testimonial: "Fantastic help. Any input is helpful particularlu when associated with other replies. Thanks again! Ralph"
  • 10865 Answers
SOURCE: need an owners manual for troy built chipper
Hi. Here is the link to the troy-bilt page which will permit you to a free download of the manual you need. Joe
http://troybilt.custhelp.com/app/answers/detail/a_id/338/session/L3NpZC9PbjI2d1Viaw%3D%3D
4 thumbs up please. thanks.
Posted on Oct 07, 2010
Where can I find a manual for a Superr Tomahawk chipper/shredder model #10635?
Google (Super Tomahawk)(10635)(manual) without parens.
Sep 19, 2018 | Heavy Machinery
Trying to no avail pull the belt pulley off my troy bilt tomahawk chipper there is no set screw ant ideas .I did pull off the two boltsm on back of pulley? model 47259
check the back of pulley there might be 4 holes they will possibly be pusher holes to loosen the pulley from the shaft .
Oct 10, 2015 | Troy-Bilt Heavy Machinery
I need a parts and owners manuel for a Super Tomahak Wood chipper made by Garden Way Mfg. Co. where do I go to get one?
Hi and welcome to FixYa. I am Kelly.
Go to this site:
http://www.brentchalmers.com/
I note your looking for the Super Tomahawk. If you can come up with a model number I think I can find your parts manual for sure. (or at least an on-line parts list.) Also.... If you can come up with an engine number like OH120 or L90 off of the engine I can find you a manual for the engine also.
This is the list of Manuals available there:
  • 1983 W-W Grinder Inc. Manual and Parts List Super Tomahawk 5-8-2G/C and Tomahawk 5-8-2G/M Chipper/Shredder (40 Pages)
  • 1989 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1989 Troy-Bilt Technical Manual 4HP, 5HP, & 8HP Models Tomahawk Chipper/Shredder (12 Pages)
  • 1991 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1991 Troy-Bilt Knife Kit number 1772231 (1 Page)
  • 1992 Troy-Bilt 5HP Model Service Kit (Part Nos. 1901153 and 1901804) For Chipper/Vac (1 Page)
  • 1992 Troy-Bilt Owner/Operator Manual 47260, 47261, 47271, 47272 Chipper/Vac (60 Pages)
  • 1993 Troy-Bilt Sales Brochure Chipper/Vac (4 Pages)
  • 1993 Troy-Bilt Owner/Operator Manual 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (44 Pages)
  • 1993 Troy-Bilt Parts Catalog 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (16 Pages)
  • 1994 Troy-Bilt PTO Chipper/Shredder Owners Dog Clutch Kit 1902404 (1 Page)
  • Hopefully your model is one of the above.
    Here is link to the Parts manuals:
    There are 90 parts manuals there.
    Again with a good model and engine number I can probably come up with your exact manuals.
    Thanks for chosing FixYa,
    Kelly
    Oct 20, 2010 | Troy-Bilt Chipper Shredder
    Where can I get an owner's manual for a Troy Bilt Super Tomahawk chipper
    Here: http://www.brentchalmers.com/
    Keep all of those fingers out of the shredder!
    Hope this helps, if so pls leave feedback, if not let me know!
    Jan 25, 2010 | Troy-Bilt® Briggs and Stratton Chipper
    Misplaced operation manual for Troy-Bilt Briggs & Stratton Super Tomahawk Chipper/Shredder 8 HP Can it be downloaded? What kind of oil does the chipper use?
    Straight 30w NOT 10w-30
    prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
    I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
    Oct 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
    Drive belt and a manual for 8 hp tomahawk chipper shredder
    did you find a manual? mine is 8hp Super Tomahawk, model 47258. I have manual, but not parts diagram. I need parts, flails and tamper. Got any leads? twinblade88 at hotmail dot com
    Jun 08, 2009 | Troy-Bilt® Briggs and Stratton Chipper
    Looking for manual for troy-Bilt super tomahawk wood chipper
    I have the both the manual and parts catalog for Troy-Built 8hp Tomahawk, can send them to you for the cost of coping and postage if you haven't found them yet.
    Ron Bowman, PGYBCK@AOL.COM
    Apr 25, 2009 | Briggs & Stratton Heavy Machinery
    No where to go
    Try ebay...I have found a lot of parts for my troy bilt chipper shredder on there. Sometimes you can also find a local dealer who might have parts laying around also.
    Apr 20, 2009 | Troy-Bilt® Briggs and Stratton Chipper
    Troy-Bilt Super Tomahawk Chipper Shredder Parts Manual 5hp 8hp Garden Way Logo
    1,618 people viewed this question
    Top Troy-Bilt Heavy Machinery Experts
    quennie732
    Mike
    lnbn1975
    Are you a Troy-Bilt Heavy Machinery Expert? Answer questions, earn points and help others
