HELLO MR GRUMPY I HAVE A SOLUTION FOR THIS IF YOU CAN DO IT YOURSELF ALL YOU NEED IS A PP9 6 VOLT BATTERY 2 WIRES AND 2 PINS THIS INJECTES 6 VOLTS ..... THE 360,S SOUND COMPATABLITYS ARE __Audio __Multi channel surround sound output __Supports 48khz 16-bit audio __320 independent decompression channels __32 bit processing __256+ audio channels ....__..........................................__PLEASE DICONNECT ALL RF LEADS /POWER SUPPLYS/WIRED PADS FROM 360 BEFORE TRYING THIS AND ANY DISK IN THE CONSOLE TAKE 360 APART TILL YOU HAVE THE 360 BOARD IN FRONT OFF YOU USE THE GRAPH ON THE BOARD I HAVE POSTED AND FIND THE PART ON THE PIC LOCATION 8N/8P MEANING 8 POSITIVE 8 NEGITIVE ......__NEXT BATTERY WITH 1 WIRE COMING FROM NEG AND 1 WIRE COMING FROM POS YOU ONLY HAVE TO TOUCH POS WIRE TO POS LOCATION ON BOARD AND NEG TO NEG ON BOARD BOTH AT THE SAME TIME NOW PUT YOUR 360 BACK TOGETHER ....WARNING DONT PUT NEG TO POS OR VICE VERSA I WONT BE HELD RESPONSIBLE FOR ANY DAMAGERS ETC
HERE IS THE LOCATION ON THE 360 BOARD
LOCATION ON 360 BOARDBOARD
GLAD THIS WORKED FOR YOU STUART360
THANK YOU STUART360 I TRYED THIS AND IM NOW BLASTING MY WINDOWS OUT WITH CRYSTAL CLEAR SOUNDS THANKS AGAIN
i left my xbox in my car when it was below freezing for about 3 days and when i brought it back in and tryed to play it it would not boot and when it did the sound would not work and has not worked since.
