Does anyone know where I can get a Braun ET55 calculator repaired? The following buttons do not work: decimal point, plus, minus, M+, M-, MR. This is my favourite calculator which I used for many years. Since retiring, I've hardly used it which may be the problem, although it worked fine a few months ago.
SOURCE: how do i change the mode on my Casio fx-82au plus calculator?
Press SHIFT [MODE] to bring up the mode screen. Press 8 for NORM, then 2.
Bear in mind that if the magnitude of the number is too large or too small the calculator will switch to scientific notation anyway. For example, if a number has twenty leading zeros then it won't fit on the display unless it displays it as a power of ten to the negative twenty.
SOURCE: I have a Casio fx-300ES PLUS and I'm trying to
In Casio, DMS button has the following symbols:
a degree symbol, apostrophe, and a quotation mark. :)
http://www.google.com.ph/imgres?um=1&sa=N&hl=en&biw=1366&bih=705&tbm=isch&tbnid=zh5-w4644l_dOM:&imgrefurl=http://salestores.com/casiofx300es01.html&docid=-mW6QXzNy3n2kM&imgurl=http://salestores.com/stores/images/images_747/FX300ESPLUS.jpg&w=245&h=500&ei=EfYlUqLSJIv8iQeH8oDYDQ&zoom=1&ved=1t:3588,r:4,s:0,i:89&iact=rc&page=1&tbnh=187&tbnw=89&start=0&ndsp=22&tx=86&ty=103
-- the DMS button is found under the square root sign.
