How to switch from internal memory to SD card
SOURCE: internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
SOURCE: memory card needs formatting.
take a look at your memory card to make sure it is not locked, then try formatting you memory card
SOURCE: Trying to transfer pics on internal memory to my SD card.
Set the image storage setting of the camera to Internal.
Once it is set to internal, put the card in the camera and press review.
Copy the pictures from the internal memory to the card.
SOURCE: switching from internal memory to memory card
Push the MENU button and advance through the options until IMAGE STORAGE comes up. Setting this for AUTO will route all new pics to the memory card, using internal memory only if the card is full.
SOURCE: pix transfer from internal to card
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card?
Answer :
Follow these steps:
