Coleman 10' X 10' Sundome Tent 9160K101 Logo
A
Anonymous Posted on Nov 19, 2012
Show set up of great outdoors holiday 1310 tentshow picture of tentthe great outdoors holiday 1310 tent
1 Related Answer
DRoper
  • Posted on Dec 13, 2009
SOURCE: where can i get assembly instructions for great outdoor tent
You can get instructions for Great outdoor tents if their not too old from Great Outdoors Hastings
Pitching instructions for a great outdoors executive 320 tent and sunroom
This is a duplicate of a previously asked question on FIXYA from 2012, where an exact set of instructions could not be found, but two proposed answers were given.
For a similar but not the same tent, the scanned document still exists online:
https://drive.google.com/file/d/0B1SdA-vKLONwZ05vTGZKdF9BTzQ/view
https://www.fixya.com/support/t7407226-need_pitching_instructions
Quoting from FIXYA question from 2012
Wollocks
Jim,
these are the instructions I devised as I had no instructions either...
Great Outdoors Executive 320 tent
Two rooms plus a fully enclosable veranda.
(4.9m long x 4.3m wide x 2.4m high)
Main Tent Assembly :
Lay the tent out on the ground (making allowance for the slope of the ground, prevailing wind, general access, etc).
Peg down the main corners and centres of each wall, keeping the tent square and evenly tensioned. Peg down remaining loops.
Assemble two sets of side support poles. These have been numbered (from the front, looking towards the tent (ie, facing the veranda)) :
Left-hand side : L1, L2, L3, L4 & L5 (corresponding to poles 1, 24, 3, 4 & 1).
Add front & rear supports LF1 & LF2 and LB1 & LB2 (ie, 2 sets of poles 5 & 9).
Right-hand side : R1, R2, R3, R4 & R5 (corresponding to poles 1, 24, 3, 4 & 1).
Add front & rear supports RF1 & RF2 and RB1 & RB2 (ie, 2 sets of poles 5 & 9).
Place poles in the loops along the sides ensuring that the 4 brown loops (at each end of the sides) are looped behind the projecting studs (this ensures the sides don't slide into the centres.
Lift & tension one side, then the other.
Assemble the centre poles (numbered C1, C2, C3, C4, C5, C6 & C7 (corresponding to poles 12, 13, 8A, 24, 3, 4 & 8)).
Slide the centre poles through the centre of the tent. Use poles 14A & 15 to hold up the rear of the tent, poles 14A & A in the centre, & two further sets of 14A & 15, one set at the front of the tent & one set for the veranda. Tension by expanding the poles.
Assemble poles A, BE, C2, BE & A through the centre of the tent, clip onto ridge poles & tension. (Note : poles A should be inserted from the outside, through the elasticised holes before being inserted into poles BE).
Attach a guy rope to the rear of the tent (top of centre pole 15) & tension.
Veranda Assembly :
Assemble 4 sets of poles (10 & 30) & place in corners & centres of the veranda. Attach guy ropes & tension. Attach veranda walls (using Velcro strips).
Porch Assembly :
Select which side is to be an entrance. Unzip the window covering & use two poles (10 & 30) to lift it. Tension with 2 guy ropes on each pole.
hope the above helps.
Warwick Annear
[email protected]
Does anyone have the instructions for a Great Outdoors Drifter dome tent? Thank you :)
I saw several youtube videos showing how to set one up. Youtube can be searched.
2answers
Hello I have a great outdoor Manor tent an no instructions could you please help
I found this Instruction sheet for my Great Outdoors Manor Tent. It's from the range that was available in 2002. I hope it helps.
Square tent with 2 types gazebo poles, varenda, 2 side windows
the 2 longest of the poles go in an x over the center of the tent and the 2 shorter ones go arch to the sides. http://www.wenzelco.com/details.aspx?NavID=412
shows a picture very similar to your tent. If you go to image 2 it shows it with out the fly. now if you got 2 sets of 4 poles, 2 long and 2 short, and one set is all aluminum, then I would go with the aluminum set. It is less likely to collapse in high winds.
4helpful
3answers
Where can i get assembly instructions for great outdoor tent
Top Coleman Sport & Outdoor - Others Experts
Kardoc
vince
john h
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
