SOURCE: I need a manual for a Necchi Royal Series,
Hi! I found your manual at http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/4795_Instruction_Manual.htm
Happy Sewing!
Robbie
SOURCE: would like manuel on the
I suggest to go to the necchi website & contact the parts dept & see if they have one
SOURCE: my wife has a necchi
Hi
I had to open up the machine and figure out how the feed dog worked
which was pretty easy. You will need a Phillips head to remove the
protective cover on the bottom area of the sewing area, and the back of
the machine that has the side with the presser foot lift or drop. Keep
the screws in a bowl or a container to keep them from being lost and
make sure you remember where the screws go...there are two that are
removed that are different from the rest. Once you access the unit you
will look into the bottom area and look at how the feed dog moves up and
down....its okay to touch it. Once you see how it moves up and down
you will also see that there is a black screw without a head on it that
has an impression for a flat head screwdriver (a small one) and has a
nut attached. When the screw is turned in either direction it lifts or
drops the feed dog. The nut must be loose to adjust the screw and
tightened once you raise it to the desired height. Make sure you try
out the stitching before you close everything up as your bottom stitch
will be affected if the feed dog it to high.
BTW take out the needle before you start messing with the machine so you don't hurt yourself.
And while you are in there, clean the lint out.
My kids lost my little brush and seem ripper that came with it, so I use a small paintbrush to clean out the machine.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
