I would like to have a detailed wiring diagram for my bestwill fishing camera in order to rewire my underwater fishing camera. If you can please email me some information that would be awesome/and or information how to do rewire it, or a website that would help me if you dont have that information.
Thank You
Caper
Recommend contacting Pyramid customer support directly here
http://www.pyramidcaraudio.com/ContactUs.aspx
SOURCE: 917.271021 Wiring Diagram
here's one, not very good. Let me know if this doesn't help and I can clarify the locations of numbers. 4x4papa
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
SOURCE: 2000 olds alero v6 spark plug firing order diagram
2000 Oldsmobile Alero 3.4 liter V-6 VIN "E"
Hope helps (remember rated this).
SOURCE: I have a 1986 Chevrolet pick-up I am rewiring the
Heres your wiring diagram it shows the complete heater wiring. hope this helps you,
