1999 Mazda Protege Logo
karina garcia Posted on Sep 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What could be wrong with my 99 Mazda Protege now? 5 months ago it overheated, replace alternator and belt, now battery wont hold charge and is overheating again, and loosing water coolant.
5 months ago my car started squealing and I ignored it a month later it overheated and I had to replace the...not sure if it was the alternator or the radiator, and the belt which was gone. The sound did not stop but I ignored it, now the battery wont last long and is overheating again plus is loosing coolant. Can anybody tell me what can be wrong now? I paid $451 that time
richie46
Level 3:
Top Expert:
  • Mazda Master 12,962 Answers
  • Posted on Sep 05, 2017
richie46
Mazda Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2943336
Points
58151
For a coolant leak you need to check all the hoses and fittings by radiator, heater core, expansion tank for leaks and/or integrity. Also make sure that your water pump is not leaking along with radiator cap and thermostat body. Overheat condition has no effect on battery - if it does not hld charge it is because it is chemically worn out and needs replacement. Until you correct water loss, have extra water in car at all times and run your heater full blast - windows open!!!!
5 Related Answers
Anonymous
  • 15935 Answers
  • Posted on Jan 20, 2009
SOURCE: overheating, coolant levels vary, battery
Thermostat is faulty - replace it.
Also, check the radiator fan is operating
Anonymous
  • 111 Answers
  • Posted on Nov 06, 2009
SOURCE: timing belt on 1996 mazda protege slips during startup
Hello, this to me sounds like your fan belt slipping (not timing belt). To adjust the fan belt you need to undo your bolt on the alternator, pull it tight onto the fan belt and while holding it tight do the bolt back up tightly. this will stop yoour fan belt from slipping. I hope this helps.
Anonymous
  • 784 Answers
  • Posted on Dec 03, 2009
SOURCE: engine overheating
The coolant flush on radiator doesn't do any good. Since you have changed all the key components and still gotten overheated, then the root cause of the problem is the radiator. It got clogged up in small tubes blocking coolant flow. No matter how good the water pump is working but the radiator got clogged up, coolant is not circulating therefore the heat from the engine can't be dissipated to the radiator. Replace your radiator, don't even think about rebuild it. It has been used for 11 years. Make sure to have the correct coolant/water ratio to keep radiator life for years. Good luck.
Testimonial: "Thanks, it was the radiator afterall. They claim hose was attached too tight; caused it to chip. I think I was taken for a ride by AAMCO & Valvoline."
Anonymous
  • 454 Answers
  • Posted on Jan 13, 2011
SOURCE: my 03 protege 5 overheated and blew coolant out
burned it up!
Anonymous
  • 3640 Answers
  • Posted on Aug 22, 2011
SOURCE: 2003 Mazda Protege sat idle
ok for the belt, it may be weather beaten or small cracks in it. and as for the alternator if its bad just get another one, and have a friend or a independent garage do the job. 900.00 dollars is way to high! thats a ripoff. call around and im sure you can have both of these things done fairly cheap! as for the alternator, if there is a rebuild place that rebuilds starters and alternators. this would be your best bet. i have had a alt. rebuilt and i only paid about 80.00. they are like new when they rebuild them. good-day !
This is yet another question about my 1999 mazda protege, I replaced the battery and altenator but the battery light still came on after just a few short rides in the car, what else could be wrong????
Check the wiring to the alternator for signs of overheated connectors, replace as needed and don't use crimp connectors solder all wiries and shrink tube them to insuklate the solder joints.
Mazda protige 1997 overheating
Some restrictive pulley tension usually is what causes a good belt to wear prematurely. Sounds like the water pump may be the culprit all along...(one of 2 belts) Be sure to have the alternator itself tested (free) at most parts stores...could be a combination of concerns. Hope this helps.
2helpful
1994 Mazda Protege, new battery, new alternator, wont charge
You must have blown a master fuse or fusible link.
Refer to the maintenance manual.
this happens sometimes during a jump start or a direct short in the elect system.
r/
David
1helpful
2answers
Altanator keeps dieing.
A fresh charged battery does not mean it is a good battery.The battery is working the alternator to death,replace it,it has a bad cell,or the amps are to low,and has a short in it.The alternator senses the battery is in bad need off charge,and puts all out until the alternator has nothing left,This is the most likely cause of this problem.Also be sure the battery cable ends are shiny clean when replacing the battery.
1helpful
2answers
Squeaking belts
If it's not the belts, it might be your alternator. I had the same problem. I would have the belts tightened, then the problem would come back a few months later. Ended up that the alternator was bad. Replaced alternator, battery and belts and it hasn't happened since.
2answers
Belts making noise
Simply check is to replace the serpentine belt tensioner. Looks like this:
http://www.1aauto.com/1A/SerpentineBeltTensioner/Mazda/Pickup/1AEBT00008/975584/1/?utm_source=google_base&utm_medium=cpc&utm_campaign=google_base_api
Another reason you might have alternator going to die. Try to rotate the alternator rotor without belt on it. If you need to use force no free rotation, replace the alternator.
Please kindly let me know if you need more info
Good Luck
Not charging after new alternator and battery my 94 mazda protege has beeen through 3 alternators in 2 months and the battery and alternator are brand new, less than a week or two old and still not...
check for a big heavy fuse nearf the battery,i dont know if it has one?? iam a general mechanic not a mazada specialist,try this trick ? start engine and hold rpm at 1500,then disconnect battery and see if engine stops if it carries on running then altenator is working.If it carries on running then turn on all electrical thingys except the radio.If its still running ok then fault is elsewhere like a discharge overnight.
Top Mazda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mazda Expert? Answer questions, earn points and help others
