It appears your calculator's display mode is set to scientific. To get rid of the exponent, change the display mode. Unfortunately, without knowing the make and model of your calculator I can't tell you how to change the display mode. Would you care to specify the make and model of your calculator?It appears your calculator's display mode is set to scientific. To get rid of the exponent, change the display mode. Unfortunately, without knowing the make and model of your calculator I can't tell you how to change the display mode. Would you care to specify the make and model of your calculator?
Press MODE. Highlight "NORMAL" on the first line and press ENTER. Highlight "FLOAT" on the second line and press ENTER. Exit the mode screen by pressing 2ND [QUIT].
Had the same issue and just tried this....and it worls [PS dont use the littel plastic hotshoe cover as this keeps the microswitch depressed]
Originally Posted by Tdragone If you manually 'help' the flash to open and it doesn't pop; the microswitch under the rails of your hotshoe is probably stuck in the down position as mine was. I used a toothpick top pop it up and it works now!
If you want to keep the program on the computer but just run it when you need to then go into MSCONFIG and uncheck the box for the anitvirus program and reboot the computer. If you want to remove it completely from your system then go into add/remove programs and uninstall the program and it will get rid of it completely and then reboot.
TI - 84 Silver Plus Edition is what I have.
