Computer will not boot even to bios screen.no display on lcd or external monitor
Rommel, where is the video memory located on the motherboard? Thanks.
Your not getting power? When you plug the laptop in does the Battery charge light come on? Are you getting power to the laptop? Do you have a multimeter to verify voltage from th AC outlet to the AC jack? Or ,the power gets to the laptop and push the on/off button you get no response? Or, you push the on/off button and the laptop starts then shut down? No lights, no leds blink. Remove battery, Try another cord/charger. Has it been dropped or damaged that would jar loose a connection, or pulled by the cord resulting in a damaged AC jack?
SOURCE: Acer Aspire 5315 lcd screen corruption. External lcd partially ok
i know your problem. even if you change the inverter it will not work. the real problem of your notebook is vga memory or video memory. use hot air to resolder your memory. trust me!
SOURCE: Dell Latitude D800 will boot but no display
The symptoms you are describing are a failure of the VRAM of the video card. To resolve will require replacement of the video Card:
http://cgi.ebay.com/Dell-D800-M60-8500-FX5200-Graphics-Video-Card-M6688_W0QQitemZ330394777550QQcmdZViewItemQQptZPCC_Video_TV_Cards?hash=item4ced1037ce#ht_536wt_1166
Shine a flashlight on the dark screen to see if you barely
see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be
any kind of monitor even the old big fat crt monitors as long as it has a vga
cable to connect to your computer's vga port. If so that proves your
video card is ok. The video will show on most systems when you reboot
without you having to do anything. Some systems will require you to hit the FN
(Function key) + F1 thru F12. Hold down the FN key then hit the correct
key for displaying on the monitor (F1 thru F12). The correct key will
normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,
then your screen is bad. If you see no icons by shinning the flash light
and nothing shows on the external monitor, then most likely your video card is
bad.
The lcd inverter can be purchased on ebay for less than $15. It
is located at the bottom of the lcd screen. You'll have to remove the
plastic strip that is around the lcd screen by removing the plastic or
rubber bumpers that have screws under them. Normally there will be
bumpers at each corner and maybe along the insides on the plastic
strip. Remove the bumpers, the screws and pry the plastic strip off
with a little force with your fingers. You will then see the lcd
inverter at the bottom of the lcd screen.
Just put your computer's name and model in the ebay search followed by lcd inverter.
Actually it looks like your laptop uses the LED screen instead of LCD so
it will not have the LCD Inverter. You will have to purchase a new
screen. I found the one below on ebay.
http://www.ebay.com/itm/Packard-Bell-EasyNote-TJ68-AU-065UK-LAPTOP-LED-LCD-SCREEN-/400293582889?pt=US_Laptop_Screens_LCD_Panels&hash=item5d335b5829
