After installing the processor mother board will not power it self. but without the processor mother board will power up. all the sys fans will work but power led will not light.
SOURCE: need 64 bit usb drivers for my motherboard - a Biostar G41-m7
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=421
try this one
SOURCE: After installation of Biostar G41-M7
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive Test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty hope this helps
SOURCE: on board led indicators are
remove all ram memory wait 5 min,make sure to unplug from a/c,reboot with no mem should hear beeping unplug reinstall mem should boot ok if mem good,good luck!
Hi, intially when you install the chipset drivers from the website http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=421 it will install the USB 2.0 drivers for you as it is already in the package. However, I now currently have the same problem as you as it seems that either a Windows Update or other software has removed this.
hope this helps
