Purchased NIB just powered up for the first time. Unit seems locked. Do I need to program it. Is it 'locked' other than by dial lock? I thought I should be able to manually enter a frequency. Is this not the case? Many thanks
Hi Bob,
Firstly, you say you purchased the unit NIB = New In Box, so that would mean you should also have a user manual that came with it.
If this is not the case, take the whole box and dice, together with the purchase receipt to the place of purchase and ask for a copy of the user manual, which won't cost a thing.
If, on the other hand you do have the manual, read the instructions carefully, before you turn the radio on.
It will guide you step by step on how to get your radio setup & running.
And if frequencies are required to be programmed into it, it will tell you exactly what is required to do so.
If during the course of setting up your radio for reception, you encounter problems, then towards the back of the manual there will be a trouble shooting section.
All being well, you should be up and running, if you follow my advice.
I hope I have assisted you.
Best regards,
Peter
