Small black border on all sides. Picture will not fill screen.
SOURCE: Sony Trinitron - Picture Disappears
Hi, IK circuit is engaging which basically means the picture tube is getting tired, the only "fix" is temporary (may get another year out of it). You have to increase the "screen control clockwise".
Remove back of set, follow large black or red wire attatched to picture tube down to the flyback transformer, mounted on flyback are two black controls, one is focus (leave it alone) the other is "screen", adjust it clockwise approx. 1/4 inch, remember that this is a high voltage circuit so use one hand in the set the other hand out of the set at all times,any questions ? e-mail me back, good luck, BMW Rider
SOURCE: Sony WEGA 36" Trinitron HD
u have a problem with your power supply circuits. ur regulator circuit is not function well thats why ur picture is a little bit smaller
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I
have over 10 years experience in electronic tech
support.
I
know this isn't what you want to hear, but the problem you've
described can't be fixed with troubleshooting.
Your TV
will have to be repaired. There is a part that has developed a defect
and needs to be replaced. If you're still in warranty, the TV will be
repaired at no charge to you. The warranty would likely be at least
one year from the date of purchase from the manufacturer. If you
purchased an extended service
plan
they will repair the TV at no charge as well.
If the TV is no
longer in warranty, it will likely cost a minimum of $150 parts and
labor. This is assuming that you only need one circuit
board
or small part. If the problem is more than one of the circuit boards,
the price of repair could go much higher.
I hope I've provided
you useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you
today.
Please let me know if I can be of further assistance.
SOURCE: Sony Trinitron Wega TV keeps shutting off and red
There are two Ic's that need replacing on the Deflection Board (D) board.. These regulate power for the High Voltage and Chopper PWM circuits. The IC location on the board are IC6501 and IC8002
