Rear passenger window will not roll back up
SOURCE: Radio Code for 1999 Mercedes E430
If you call your merc dealer they should give it to you on the phone, if not have a look at this web site, if not, then if you take out the unit and let me know the s/no: i will see i have it.
http://www.radio-code.co.uk/code-entry-help.php
[email protected]
SOURCE: Passenger side window in 1997 E Class Mercedes
i m assuming it is your right rear window. it is the most common to fail on that model. I would remove the door panel and inspect your window regulator. the drive cable probably broke. You can disconnect the window from the regulator and manually slide it up and prop it in place with a piece of wood. that's what I did when I did roadside for benz. Hope i have been helpful
SOURCE: I have a 1983 sd300 Mercedes trouble
Replace the window switch, if that doesnt work remove door panel and replace the regulator for the window.
