It seems to work normally. It projects for about 30 seconds (after the warm up of the seconds). The fan seems to be working as I can feel cool are being pumped out and see it rotating. The projector is not warm to the touch after this. the air even coming out of the fan does not feel to warm either. the 30 seconds can range to 25 or so seconds.
SOURCE: Sanyo Projector
Hi there
First make sure that your lamp timer & filter timer ( if available ) is reset.
If the problem still occurs , take a flashlight and check if your fans is running a normal rate when the unit is switched on.
It's easy to spot. If you can't spot it with the eye - take a thin piece of paper and touch the fans slighly - you'll hear the difference immediately - in wich case it woul need replacement
SOURCE: my projector turns on then off
Probably your projector filter is full of dust, and probably even the inside id full of dust. You need to clean the filter and you need to clean the inside. The fan starts coz the lemp inside cant get any air, as soon as you turn the projector on it gets overheated.
Go to a pro and let him/her clean your projector good, then it should work properly again. And make sure that you clean the filter at least 3-4 times per year.
Good luck
SOURCE: Sanyo PLC-XU33 image displayed for 10 seconds then turns off
Owner decided to upgrade to a newer projector. Lamp was too expensive.
