Windows XP operating system.
First, Cold-Start the machine, unplug, remove battery, hold down on.off button for 30 sec., leave battery out, plug in try to boot normally, is the HDD led blinking? OR, System restore/recovery. At the Coby logo screen appears, press and hold the F7 key to start system recovery, follow instructions. OR remove HDD test, replace if necessary.
SOURCE: Windows XP desktop does not fit on my netbook screen- too big
Right click the desktop,
choose display settings
slide the slider to your choice, may have to test.
Should be good.
Regards
Richard.
SOURCE: Dell Inspiron blank screen
You can restore your system in your safe mode.
To use System Restore to restore Windows XP to a previous state, follow these steps:
If
you successfully restored your computer to a previous state, and the
computer is performing as it should be, you are finished.
Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
SOURCE: Samsung N120 Netbook won't start Windows. stuck on black screen.
See if you can download it from Microsoft. It seems to be related to the languge translators in Windows (NLS file).
SOURCE: My Eee PC netbook won't start windows
try to press F8 after bios splash and start computer with options "disable restart with error" or something like that. then you gonna get a blue screen and a error write down that error and give it to me.
SOURCE: Random Blank screen at startup. All lights runed on.
shut it down properly from the command line or/and keep power button pressed for 5 sec's or so
