After cleanig my stove top, the only ignitor that is working is the middle burner. All four knobs on the front turn on the middle burner ignitor. The other four knobs will not turn on the ignitors. I did clean the operating panel and I'm thinking so type of reset may be involved. All worked fine before the cleaning. Hoping for a simple answer. thanks so much. Sandi
SOURCE: My Frigidaire PLGF 390DCA 5 burner stove (all the
One of them spark switch's is shorted. You must remove one at a time till you find that bad boy. OR replace the harness.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: ignitors keep firing by themselves after my aunt cleaned the stove
Hi davemoo2, I would make sure that the all the burners are put together correctly .. next check to see if a selector switch may be pushed in or shorted . also check the that the ingitors are know grounded out.. let me know what you find out... kraxytech
SOURCE: Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago
You have water left over from cleaning and it is shorting out the igniters at the knobs, not the burners. I guess the solution is to wait until it dries out unless you can open the top and maybe use a hair dryer.
SOURCE: replacing top burner ignitor on Frigidaire
all the screws under the cap burner need to come out of all the buners inorder to get the top off
SOURCE: My frigidaire gas stove will not heat the "bake" part
If the bake
ignitor comes on - check the
amperage on
the bake ignitor wires when it's on. If the ignitor is a round style -
amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If
less
than 2.5A or 3A respectively - replace ignitor.
Ignitor part numbers for round style ones: 4342528,
WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020,
5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if
you can splice the wires.
OK, never mind and thanks anyway. I had the burner caps sitting in the sink while I was testing the burners to make sure they worked after cleaning. I had no idea the burners wouldn't work without the caps. (It's quite a design, really.) The old stoves were so much simpler! :) Boy, do I ever feel dumb!
