SOURCE: Unable to set pairing between jabra bt 125 and bluetooth device
You simply need to hold the button down for a long time, it will flicker blue at first, don't let go of the button, and it'll turn blue for pairing.
SOURCE: headset does not flash red/blue so I can pair it with my phone
To get it into pairing mode (flashing red and blue) turn the headset off. Hold the main button down until the light goes red and then off. Then push and hold that same button and keep holding it even after the blue light comes on. It will now go into pairing mode, flashing red and blue. Set your cell phone to find it and it should work.
SOURCE: old phone quit and blue tooth won't pair with new phone
Hold the volume buttons on the side while holding the call button for 10 seconds. It will reset the bluetooth and remove any other devices it may have been paired to. Then turn it off, back on and it will eventually stay lit blue and then you need to set it up through your phone. I hope this helps, I had the same problem and mine is working fine!
SOURCE: Motorola bluetooth H270 solid blue light after pairing
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
SOURCE: my bluetooth wont turn off, the blue light stays
To reset the hardware:
• Plug the charger into a power outlet, then press the
Volume Up and Volume Down buttons at the same
time. This turns off power to the headset and resets it.
