The light bulb in our microwave burnt out. Replace it, right? Can't find it, and it isn't even mentioned in the manual! Seriously? I'm not buying a new microwave for lack of a light bulb. We got this at Costco, and except for the light, we really love this oven. Had it at least three years.
SOURCE: LG MP- 1482s INTERNAL LIGHT CHANGE
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: LG light bulbs
The part number you need is 6912W1Z004B. You can this part at repairclinic.com for about $4 each. I hope this helps you.
SOURCE: Black LG microwave oven, fail light bulb inside, I
The oven lamp is accessible when the whole outside cover of the oven is removed. The lamps these days are a special bulb and would be available from a TV repair place or a appliance repair centre.Take the old lamp in with you to pbtain the correct part.
