Under the "Format for" the only options that show up are:
Stylus Photo R300
Any Printer
or
Print & FAX Preferences
Your online instructions for borderless printing with this model on a Mac OS X (I'm on a 10.4.11) suggests an option in the window that reads
"Stylus Photo R300 borderless" and that does not appear.
What to do? Can I download a newer driver perhaps?
SOURCE: epson stylus photo R300
>disconnect printer from the computer
>powercycle the printer
>check for obstructions / torn papers inside unit
>if issue still persists - hardware issue
>warranty starts from the DATE OF PURCHASE better check
SOURCE: Epson stylus photo R300 cd/dvd tray not set correctly
you can try and reset the printer with software let me no if you dont haver it
SOURCE: Epson Stylus Photo R800 (Manual Feed) missing option
I found this answer on Apple.com support discussions. Worked for me. There is more information available on the discussion, but this was enough to fix my problem.
Try Page Setup. Select to format for your printer. The choices for different all media should now be available under the Paper Size. This is a change from previous practice of creating a separate printer for each type of media.
Matt
SOURCE: How to get Epson R300 stylus monitor to work in Vista
I have the same problem with my stylus C88. Epson never did provide Vista drivers so I have never found a way to get the Epson software to work with Vista. The print driver does work so you will be able to print but you'll have to clean the nozzle manually by pushing the button on the printer rather than using the Epson Monitor. Sorry.
SOURCE: Clean "Waste Ink Cartridge" Epson R300
Had the same problem. (its a work around without removing the waste ink pad)
Took alot of work but I fixed it.
Frist thing you need to know that error means your ink waste pad is
full. Its a $75.00 to replace but there is a work around it.
You will need this free app. SSC service utitlty.
http://inkjetprinterhelp.us/epsonSSC.html Its a great app.
Instrusctions are on the website there.
You will also have to Open the access panel on the rear of the printer (remove screw) and
look inside carefullly with a flashlight. You will see a tube (down and
to your left) coming from the cleaning pump and it will have an open
end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coat hanger wire or equivalent, and fish out this
piece of tube. Bring it to the outside of the printer, thru the access
panel.
Find yourself a suitable container
(Tupperware or a plastic cup or jar) that is not too tall. Put the tube
into this container and secure the tube and container so they won’t
come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
