In slow speed ,when i use break to slow down the speed(not to stop the car), my car goes forward, then the break works.
SOURCE: abs kicks in at low speed trying to stop. Replaced
Check the speed sensors at each wheel. http://www.ehow.com/how_4521137_replace-abs-wheel-sensor-chevy.html
SOURCE: breaking at slow speed there is a bad bearing o scrunching noise.
Yeah , You are correct. The wheel bearing is very common problem at low speed , like in a parking lot trying to park, I would take to local mechanic to have the vehcile checked out.
The repair is not very hard and no to labor intensive a few hours at most.
SOURCE: Hyundai elantra 2006 Squealling but stops when applying breaks.
I have an '05 Elantra (40,000 miles) with the exact same problem. Took it in to the dealer, and they said my rear brakes needed to be cleaned and adjusted. I haven't gotten it fixed yet, but the squealing has been less frequent since they looked at it. they must have cleaned it a little just by poking around.
SOURCE: Why does the pontiac sunfire 1998 engine shut off when you break
check the spark plugs, I use to have a festiva ford and it had the samw problem,
SOURCE: my abs light stays on although breaking seems
It sounds like you have a bad wheel bearing and you should have that checked.I would also check the passenger side as well.If you jack the vehicle so the front tire comes off the ground and try to move it from the top and bottom of the tire with a push pull type motion you will notice some movement if the bearing is getting pretty bad but sometimes when it is bad you might not feel it at all.If this is the case you will have to bring it somewere to get it diagnosed.
