Question about Nostalgia Electrics CCP-510 Circus Cart Popcorn Maker - CCP-510
Nostalgia electrics ccp - 510 popcorn maker
When the popcorn begins to pop and fill the kettle the steel rod (with the cog attached above) bounces away from the cog above (the motor) causing the popcorn to bind up in the kettle.it will not stay engaged with the motor to spill the popcorn out, however it will turn easily while its empty or if you just use a small amount of kernels(less than 1\2 ounce)
My popcorn maker won't spin the kernels. I think it's the stir rod?
There are many possible problems that will cause your agitator to not spin, But you said the gear in the cabinet comes off easily, it should not.
There is a flat part of the motor shaft that extends thru the top of the cabinet that the gear should be tightened onto with an allen wrench via a set screw. This is the first place to check. When the motor is on, you should not be able to stop that cabinet gear from turning. (not easily anyway).
Oct 25, 2014 | Gold Medal 2131 Antique Gay 90s Pinto Pop...
How to install a stir rod in a Gold Medal Product, Deluxe Pinto Pop, model 2147
Take the kettle crossbar assy off the kettle and look and see if there is a set collar above the shaft weight. If so loosen it so you can slide the weight up...enough to get the old one out and the new one in.
Mar 31, 2014 | Gold Medal Products Gold Medal 2147 120208...
When turning agitator on it gets jammed in the spur gear.
This is a hard symptom to troubleshoot, it can have many different causes.
1. Is the stire wire in the kettle straight and spinning freely?
2. Does the agitator shaft spin freely in the crossbar?
3. Is there a small needle bearing on top of the spur gear attached to the kettle? it is a small metal circle that spins independently of the agitator shaft located ontop of the kettle spur gear, it can fall off.
4. The plastic block in the cabinet roof that has the motor spur gear coming out of it, is it cracked?
5. Does the motor turn when the switch is turned on with the kettle in the dump position?
All of these can lead to an answer of why the agitator stops turning while popping.
Sep 06, 2013 | Gold Medal 2656 Ultra Popcorn Maker
Popcorn machine model tpc-603 manual
Treat Time Model TPC-603
Turn on light and popcorn buttons, for 2 minutes to heat up the popper's kettle.
Then turn off the popcorn button, this stops the turning gears while loading oil and popping corn.
Warning the stainless steel kettle will be hot. Might want to wear an oven mitt.
1 tablespoon of oil (I use coconut oil) and 1/3 cup of popping corn. This makes est. 6 to 8 cups of popcorn.
NOW turn on the popcorn button so the gears start turning, this turns a wire on the bottom inside the kettle to keep the kernels from sticking or burning to the bottom.
If making multi batches, during the process it states in the manual to allow it to cool 5 to 10 minutes. I normally pop 3 to 4 batches and then let it cool down.
When finished popping, turn off both the light and popcorn buttons.
Dec 28, 2012 | Kitchen Appliances - Others
I DO NOT HAVE COOKING INSTRUCTIONS FOR MY KPM-508 POPCORN POPPER
The instructions say make sure kettle motor is plugged in. Turn unit ON with switch on crown of machine. Allow unit to run for 3-5 minutes to heat up kettle. Turn unit off. Add 2 teaspoons of your favorite popcorn cooking oil to the kettle. Then add 1/4 cup of popcorn kernels to the kettle. Turn the unit on and close the door. When popping sound slows down turn the unit OFF. Flip the kettle over with the crank handle to empty the kettle. Repeat process until desired amount of popcorn has been popped.
Jun 09, 2011 | Nostalgia Electrics Helman Group KPM-508...
The popcorn gets stuck in the kettle until it burns
I have a Popcorn machine from Nostalgia too that had this problem. I cleaned it out and everything but it still had the problem of the it getting stuck. After days of analizing, I found the solution. after a while the ceiling of the popcorn machine starts to fall in, lowering the handles of where the kettle goes. making the knob that turns being lower that the one that makes it turn, causing it to get stuck, all I did is add so leverage so the kettle is once again at the same level or higher. Making it turn with greater force and not getting stuck. In other words make sure the turning mechanism is leveled and not one lower than the other. preferably the kettle part being higher.
Jan 09, 2011 | Nostalgia Electrics Helman Group CCP-509...
Ccp-509 popcorn kettle stop spinning when popcorn begins to pop. It won't pop out of the kettle.
Normally that is caused by too many kernels used. It pops too fast and jams up in the kettle. It could be a problem with the kettle though. Call 920-347-9122 for help with it.
Feb 13, 2010 | Nostalgia Electrics Helman Group CCP-509...
Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
Sep 01, 2009 | Gold Medal Kitchen Appliances - Others
Mkettel
Have a look here
http://www.amazon.com/Nostalgia-Electrics-CCP509-Full-Size-Popper/dp/B0000CFW9M
Perhaps your problem like this?
When the kettle is popping popcorn, the metal rod with gear on the end pops out of place. Therefore, the kettle stops spinning and the popcorn burns.
>The allen screw that holds it in place need to be tighten.
Jan 31, 2008 | Nostalgia Electrics CCP-509 Popcorn Maker
Kettle Keeps jolting out of place
Popcorn popper is approximately three weeks old and now the popcorn clogs up in the hopper (cooker pot), the gear quits turning, and we have to pry the popcorn out. It worked perfectly when we first got it and now it is nothing but a pain to use. We tried several popcorns, cooking oils and amounts of oils, but the problem continues. I noticed the small spring located on the lower shaft doesn't cover the entire shaft. Is it supposed to be longer? Your prompt reply for a solution would be greatly appreciated or we will have to return the unit to our local retailer where we purchased it.
Aug 05, 2007 | Nostalgia Electrics CCP-509 Popcorn Maker
Nostalgia Electrics CCP-510 Circus Cart Popcorn Maker - CCP-510 Logo
103 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Sheldon Dedek
ray gallant
ray gallant
Tom Chichester
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
