Rangemaster Kitchen Hood Logo
Posted on Jan 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Range master 50000 exhaust fan stopped working
I have a range master 50000 exhaust fan and hood. The lights both work but the fan stopped working. This is only 4 1/2 years old. Do I need a new fan or could this be the switch. When I turn the fan to the on postion 1 and 2 the red light comes on but is very faint.. The fan doesnt do anything no noise at all. Please advise with the what the problem is.
Deborah
Thomas F. Schneider
Level 3:
  • Master 2,715 Answers
  • Posted on Jan 08, 2009
Thomas F. Schneider
Master
Level 3:
Answers
2715
Questions
Helped
1106829
Points
6961
Extremely likely the fan motor.  get to it then , after removing fan blade,plug it in directly to a 110v  outlet ,just for a second to see if it works well( don;t touch it while prefoming this test,only the plug), or jumper out the switch(with electric disconnected) momentairly to see if the fan runs after turning the electric back on.
PK2229 blower stop working
Light and fan are two separate functions in your hood. The fan gets very greasy from the cooking. The grease doesn't act as a lubricant but as dirt. Remove the fan from the unit and check to see if the shaft is wiggling,or if it is seized. At this point you may need to replace motor. If it turns somewhat put a few drops of oil at the shaft, both ends if possible, and spin the fan by hand until it's loose. Replace back into hood and see what happens. Many times the bearings in these fans go dry and will not spin. GOOD LUCK FRIEND.
Exhaust fan just installed not working
Did you have it professionally installed? I would suggest contacting the manufacturer to see if the issue is under warranty. You can find the support page here: http://www.lg.com/us/support-product/lg-LSVC302ST#
The fan in my has not stopped working in a few weeks now.what can I do to make it stop blowing air
test this steps and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
1helpful
2answers
Exhaust fan and lights do not work
see this steps and fix it. God bless you
Switch If the range vent hood fan and light are not working the switch might be defective. Watch our video on switch testing and test this switch for continuity.
Selector Switch If the range vent hood fan and light are not working the selector switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rotary Switch If the range vent hood fan and light are not working the rotary switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rocker Switch If the range vent hood fan and light are not working the rocker switch might be defective. Watch our video on switch testing and test this switch for continuity.
Switch Kit If the range vent hood fan and light are not working the switch kit might be defective. Watch our video on switch testing and test this switch for continuity.
Micro Switch If the range vent hood fan and light are not working the micro switch might not have continuity. The best way to test the switch is with an Ohm meter. See our switch testing videos for help testing this micro switch.
Thermal Fuse If the range vent hood fan and light are not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Main Control Board If the range vent hood fan and light are not working the main control board may be defective.
User Control and Display Board If the range vent hood fan and light are not working the user control and display board may be defective. Check other causes before ordering this board.
#23350303200 Kenmore Elite Range hood - Range hood exhaust motor slows down
You have 2 windings in the motor that create a magnetic field. A winding is simply a coil of wire an they do not touch. when applying the voltage (turning on the fan) the windings create the mag. field causing the rotor to turn, which then of course turns the fan blade. When these windings get weak it causes them to heat up due to the resistance in the circuit and you there for loose ur mag. field... Or if the rotor starts getting restricted it will also heat up the windings an cause the fan to stop.. Time for a new venta hood....
3helpful
Zephyr Milano hood fan and lights stop working. Power is on.
Hi ronio,
I'm Harvey the Master Plumber.
Your problem is: After the power went out your Zephyr hood lights and fan don't work at all. There is a faint glow on the digital display but the fan and lights don't respond to pressing the control buttons.
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer. If OK then you have a bad control board.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
3helpful
WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Thank you,
7helpful
Range hood light failure
Hi bentson,
Your problem is: Fan works but lights will not. switched bulbs and still lights not working.
You are dealing with a bad light switch. If you have the tools and the talent go for it.
Thank you,
Top Rangemaster Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
