This is usually a sign of a bad thermal fuse. Here is the part to order.
You can check the fuse for continuity to see if it is bad. Remove the rear panel to access the fuse.
Testimonial: "Solutions was right one. Thanks"
Thank you for using FixYa!
It worked and thank you.
Great! Thanks for using FixYa!
It was the thermal fuse in my case. A simple fix and coat 14.00 $
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
