Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
SOURCE: My Brother Printer (model MFC-290c) and ink
On your printer take a look on the "ink management button"press it then look for cleaning using the arrows up and down then press ok or set or what ever the command the printer will display just try to perform head cleaning.try for several times lets say 4x don't clean too much it might ruin all other color if it has no changes try to bring it to a service center,they can soak it to a chemical solution,the head is clog.
SOURCE: i have the brother mfc-420cn
Besides the other advice you may want to check out this page
http://www.fixya.com/support/r3845491-ink_cartridge
SOURCE: Printing blank pages
Did you run the cart initialization?
Try this: (use new carts because it consumes some ink)
press menue then start mono (blue) then fourtimes arrow up button (tel-index). machine will be in maintenance mode and lights will flash. press 7 then 6 then 4 then start mono. machine will refill tubes and ph with freh ink and do some cleaning.
Leave maintenace by pressing 9 then 9. Do run a quality test print by pressing ink etc. Iy you cant see the letters and colored blocks well the ph has to be replaced.
I guess your machine is a 2.5 years old. Unfurtunately brother ph didnt last longer than that time when useing generic ink.
SOURCE: I have a brother mfc 295CN printer . i just
Mine wouldn't print black either on Plain Paper, but if I changed the settings to Transparency Paper type it would. Hope this helps
SOURCE: clean unable 46 my printer is Brother MFC-295CN
printer head not working new head required. call : 09425386687 or email - [email protected]
