There isn't one. Because it is operated by putting the van into gear, it is probably a function of the BCM from a switch on the gearbox. Check the socket for continuity to ground and also for rust.
You can access the fuse panel through the steering column lower opening. Remove the cover using the quick release fasteners. 2. On the fuse panel cover, find the number of the fuse you want to check. The diagram on the cover tells you where to locate the fuse on the panel. 3. Check the fuse to see if it is blown. Look through the clear side of the fuse to see if the metal wire inside is separated. If it is, the fuse is blown and should be replaced. There also is a fuse box under the hood by the break Master Cylinder
