SOURCE: dripping from drain spout
If you are refering to the "Dripping coming from the preasure tempature valve,Then just turn off the valve where the water goes into the heater and open the P/T valve with a bucket below it draining only emought water to get below the level where it reaches. Normally the drain valves are plastic with a Male hosebib attached. Attach a garden hose to the rain and run it out to a point lower that the vaslve in order for gravity to drain the tank.The valve opens counter clock wise. If the valve is stuck or does not drain,and you have a foor drain handy,remove the whole valve and replace it with a boiler drain valve. If The tank is located below the drain level then you will have to either pump or carry the drain water to the higher level. Replace the P/T valve and reinstall the associated associated piping. I would use tefelon tape on the P/T pipe theads. You may have to open a hot water faucet in order for the air to replace the water in the tank ,in order to drain.
SOURCE: My Rheem hot water heater stopped putting out hot
If you are not familiar with the element, I would get someone that is familiar with one and have them do it. It's not something I would recommend you do based on your question. There's electrical, pressurized water tank, and a whole lot of water that may cause you to have a worse bad day.
SOURCE: Dripping Drain valve on rheem water heater
If your water heater is 10 years old or more, it's much better to replace the entire thing before you start having additional problems with it. You MAY be able to drain your water heater and replace the valve with something more reliable, but, as I've said... if your water heater is old, this is just the 1st thing to go wrong. More will follow.
SOURCE: I think I need to drain/flush our hot water heater
hi first making sure not to burn yoursel switch of heater and drain down down water from taps this may result in causing an air lock dont worry ! at the base of the heater you have the stat and element housing first withdraw the stat then the element alowing any remaining water to drain when fully drained turn on your water supply to flush out and clean replace element and stat using plummers sealent or tape hope this helps
SOURCE: My rheem water heater doesn't seem to be heating
try setting the bottom 10 degrees hoter than the top could be in short cycle (thatis the bottom calls for heat on the bottom element and set too close so goes back to top and cycles off
