SOURCE: Dacor Oven Won;t Heat
power surges can short out the electonics in appliances. If you can locate where the tech sheet is and I would say its behind the control panel on top, look at the wiring diagram and see if there are any replaceable fuse's. Or a resetable fuse for the heating element. If not check to see if power is getting to the main control bord. If there is power there you may need to replace the control.
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
SOURCE: Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
