Well I had the same problem a week ago do I cleaned out the game packs and the game pack reader out with qutips and rubbing alcohal and I tried the game and the expansion pack on my black N64 console and every thing was fine so it probably was a glitch then for my aqua N 64 console it works now. I hope it isn't not a problem with the console it's self.
SOURCE: OMG HELP!!PLEASEEEEEEEE WIERD LINE SHOWING UP
If that didn't work, your Wii may be in progressive scan mode on a TV that's not compatible with progressive scan. I believe if you unhook the power cord and/or AV cable, it will revert back to normal resolution.
After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
not displayed correctly.
