Question about Dell PowerEdge 1600SC Server
A power outage cause dell server 1600sc to shut down & no display on the monitor
After power returned, I pushed the power button and it powers up with initial beeps. But, the monitor shows nothing (blank). and pushing any buttons on the keyboard makes no sound. Usually, some sort of beep would sound. And, yes, I tried 2 different monitors & different cords. Still nothing. This server runs my entire business and now I am dead in the water. Please Help.
  • Dell Master
  • 3,606 Answers
Hello here is the homepage.
http://www.dell.com/support/drivers/us/en/ussoho1/Product/poweredge-1600sc
There should at least be a message on the monitor indicating there is no signal coming to the monitor. The first thought that comes to mind if all is connected would be that the power supply has failed.
And maybe the graphic card.
Call also the DELL support in your country they will be glad to help
and they probably know the fault.
Contact Us 1-877-671-3355
Good luck
Posted on Nov 26, 2012
SOURCE:
  • 76 Answers
SOURCE: No Boot on 1600sc
The easy answer is: Did you ensure the CPU fan connector is attached to the PROPER motherboard CPU fan power pins? The 2nd easy answer is: Are you sure your CPU is properly placed inside the socket? Could it be tilted slightly up on one side? The more complicated 3rd answer is: I've seen people use the spray can of AIR, which, believe it or not causes a moisture problem AND can overly cool a component. Although the motherboard looks fine, it won't boot or power on until the part(s) rewarm to room temperature or the moisture dissipates. This is how I solve this problem. I remove the motherboard or open it completely up to clean it with 80psi of compressed air. (remove all components) If it had previously been cleaned with a can of AIR, I let it sit for half an hour. When putting the parts back together (leave the HD, the CD, the floppy disconnected), (oh...ensure your front panel connectors are properly on the correct motherboard pins too.) 1)take extra caution with both the video card and the memory chip slots!! Inspect the video card gold edge and video card slot for a few strands of carpet fiber or DUST bunnies wedged or attached to the card/slot (which causes the computer to not power ON) 2) Inspect the memory sticks and memory slots in the same manner. (I had to see it with a magnifying glass, to see the problem) Once back together, if it boots, I'm done. If it didn't boot, I replace the power supply. If that didn't solve it, I reposition or change the RAM memory. Attention to detail is the key to success. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 19, 2007
eagle338
  • 4889 Answers
SOURCE: response to constant beeping on the dell 1600sc server
Please provide me a complete list of components on your server and I will be more than happy to help..
Regards,
Sai.
Posted on Oct 07, 2008
  • 21 Answers
SOURCE: Dell PowerEdge 1600SC Server occasionally beeps when running
http://dell-driver.driveray.com/dell-drivers/r_3_1.shtml
Posted on Oct 10, 2008
gymowner
  • 679 Answers
SOURCE: Dell PowerEdege 1600SC not recognizing IO devices
Just go into the bios and insert the correct parameters. you shut it off before it could save the settings. Or hit fi on boot and it should take you into the bios and you cand sort it out in there. If you want an easy way, just do a system restore. Start,Programs, accesorys, system tools, system restore, just go back a day or two before you had that issue, and you should be good to go, good luck
Posted on Apr 12, 2009
info2u
  • 596 Answers
SOURCE: I have a Dell power edge 700 server. I came in
This usually means there is a problem with your keyboard connection at the mainboard end. If you keep getting this error and you can not use your input devices, you will need to replace the board.
Good Luck
C2Solutions
Posted on Jan 25, 2010
Power supply showing amber when pressing start button
There are hundreds of things that would cause that... If you can, use the Dell diagnostic disk and have it tell you what's up.
Feb 17, 2011 | Dell PowerEdge 1600SC Server
My dell mini inspiron doesn't work when i turn it on; it starts but then nothing, it is obvious that it is on but it is only a black display on the monitor. What could be the problem?
You can switch it OFF and remove the battery.
Wait for 5mins, Connect the battery again, Also connect the Power Cable to the Laptop.
Try to switch it ON, It should work.
With regards
FIXYA team
**Please post your feedback and Vote if the problem resolved as per your satisfaction**
Oct 08, 2010 | Dell Inspiron Mini 10 Notebook
My dell server 1600sc power edge is not booting with warning led in power supply
if the system has no redundant power supply.
basically you will need to replace it with the same make and model from Dell or a working 2nd hand model.
Oct 01, 2010 | Dell PowerEdge 1600SC Server
No power to dell poweredge 1600sc. Redundant power supplies have no lights.
Either the power supplies have both failed, which is unlikely, or they are not connected to a hot outlet. Frequently servers are connected to uninterruptible power supplies (UPS) instead of being connected directly to a wall outlet. Make sure the UPS is on and functioning.
Dell provides lifetime phone support for their servers so you should give them a call if you need more help tracking down the problem. (800) 945-3355
If this helps please vote for my solution.
Feb 12, 2010 | Dell PowerEdge 1600SC Server
A power outage caused server to shut down. It
The power outage is suspected to corrupt the RAM. Get in touch with the vendow and get it replaced.
Nov 09, 2009 | HP Server Tc2120 (335874-001)
Dell 1600SC Server - trying to install a video card
try repeatadely pressing delete on startup with the monitor cable attached to your onboard graphics socket but keep the new graphics card in. then you should go into the bios. change the graphics setting to your graphics car and then save and reboot. it should now work from your new graphics card
Jun 18, 2009 | Dell PowerEdge 1600SC Server
Apr 12, 2009 | Dell PowerEdge 1600SC Server
Check out this site:
http://bioscentral.com/postcodes/dellbios.htm
Write down the exact number of beeps and how long they last to find what the error means. The are call BIOS post codes and they resemble Morse Code. (ie. one long, 3 short, 2 long = RAM issue) Good luck!!
Sep 26, 2008 | Dell PowerEdge 1600SC Server
No Video Signal on 1600sc
Disconnect from the network and all other accessories, and power up the system, this might be due to a faulty device attached to the system, eg: when you connect a usb faulty device the boot takes very long time, sometime it does not boot up.
Dec 30, 2007 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server Logo
202 people viewed this question
Ekse
Clive
Clive
