Motorola MC75A Handheld Mobile Computer MC75A6PUCSWRRA9WR Portable Terminal Logo
Anonymous Posted on Nov 16, 2012
User Manual needed Motorola MC75A
How do I activate the keys, how do I customize the start menu and/or home page?
Hans Pedersen
Level 3:
  • Master 3,606 Answers
  • Posted on Nov 18, 2012
Hans Pedersen
Master
Level 3:
Answers
3606
Questions
0
Helped
2231887
Points
8683
How do I unlock a Motorola talkabout
Press and hold the Menu button (the center section with the + and - buttons to the sides) until you hear a beep (3 seconds or so). After that, when you press and release the Menu button, the Channel number should flash indicating that you can change the channel. In the future, you can toggle the keypad lock by pressing and holding the Menu button.
You can find more information on the Keypad Lock feature in the manual. See page 14 and page 21. The manual is available from ManualsLib: https://www.manualslib.com/manual/106993/Motorola-Talkabout-T5320.html . For the diagram of the Motorola Talkabout T5320, see https://www.manualslib.com/manual/106993/Motorola-Talkabout-T5320.html?page=14#manual . The Keypad Lock is described here: https://www.manualslib.com/manual/106993/Motorola-Talkabout-T5320.html?page=21#manual .
I hope this helps. I usually use my Motorola Talkabout radios with the keypad lock active. I hit the various button accidentally when working in the field.
How to get activation code
We recommend you contact Motorola Solutions.
portal motorolasolutions com
Mark
Motorola Mobility Support
2answers
MC75A after reboots shows the appcenter but freezes the screen not able to click on anything.
Can You use the buttons? Press the right button with a white bar, just below the screen. This should open the Tools menu. If it does, use Exit and leave AppCenter. If this works, You can test if the touch screen is defect or if AppCenter installation is corrupted. If the screen is ok, reinstall AppCenter.
2answers
Need to cold boot an MC75A
Press the #1 and #9 while turning on the device.
Format motorola mc75a
press power on and keys 1 and 9..
1helpful
In need of a user manual for SBG6580 wireless router
The User Manuals for many of the Motorola modems and gateways are available from Motorola on their support site: http://www.motorola.com/Support/US-EN/Consumer-Support/Cable-Modems-and-Gateways . Select your model. On the next page, use the drop down menu to select User Manual in the Select A Topic drop-down menu. Then click Search. The direct link to the manual for the SBG6580 is http://www.motorola.com/staticfiles/Support/US-EN/Home-and-Office/Cable-Modems-and-Gateways/SBG6580-SURFboard-Wireless-Cable-Modem-Gateway/Documents/Static-Files/SURFboard_SBG6580_UserGuide.pdf . Note you will need Adobe Reader or a similar program to read the file.
I hope this helps.
Bosch classic 1200 key sign showing and just bleeps wont start wash
To start a cycle when the child lock has been activated you have to keep the start button pressed for a least 5 secs. Check your user manual for deactivation of child lock.
If you don't have the manual, use the link to download a copy, you will need the Enr number from the sticker on the inner door.
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
13helpful
Machine has a flashing key sign and won't start wash cycle - t
You have probably inadvertently activated the child lock. You can start a cycle still, but you will need to hold the start button for approx 5 secs. Check you user guide for deactivation instruction.
use link to get manual if needed
Motorola V120 c
I have the same problem- Yesterday I bought my second hand and the phone number wasnt programmed into the phone either. Try doing it like this 74663# press menu and press menu again it should bring up the user activation
Top Motorola Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
