I replaced the bulb less than a year ago when the first one died. That worked great. I do not really want to dump a lot of money into this TV when brand new, larger LCD and LED are less than 2k now. What should I do. Can I test while it is off? Are there ways to test what is working and not working?
SOURCE: Samsung DLP HL-T5676S turns itself off.
i would try that first see if it work .. and if it doesnt post a comment on here and will get back to u ASAP =]
Please Rate Me
SOURCE: samsung DLP TV won't turn on
This sounds to me like one of two possibilities. First, check your ballast. If you're going through bulbs faster than you think you ought to be, you may have a ballast that is overloading. Its the 3" x 8" circuit board that connects directly to the bulb. They are plentiful and often cheap. Thats what I'd try first. If that doesnt' do it, I would invest in a new power supply board. That the board that the tv power cable hooks directly in to. This should give you a start, Comment back if you still need further help. Good luck.
SOURCE: Samsung HL-P4663W/HL is making a buzzing noise
Color wheel needs replacement is the most likeliest cause.
SOURCE: my samsung hl-p5085w is humming all the time and
Samsung is known for bad color wheels and for what you describe it surely sounds like the color wheel bearing if going out on you,you will need to replace the color wheel you can find more help @ fixyourdlp.com and if you want to buy the part you can find it @ http://www.discount-merchant.com/SearchResults.asp?Search=color%20wheel?click=52978 or @ http://www.samsungparts.com/search/search.asp , just so you can be 100% sure you will need to get the part number from the actual color wheel that you already have,
Please rate this if it was helpful,as a do this for free
Regars
SOURCE: My Samsung HL-R4667W rear projection tv turns off
Lamp or Lamp Fan For replacement Lamps Call Mats Electronics 1-800-628-1118
for other Parts/Boards Call Encompass Parts Distrubtion 1-800-638-3328
Replace Lamp!
Testimonial: "Thanks ... I will try it. :)"
