SOURCE: Sony VPL-CS4 projector
Denis, by default laptops usually output only to their own lcd panel. There must be a key combination on your laptop wich rotates output in 3 steps: lcd panel only, lcd + TV (projector), TV only. The key combination uses a special Function key (FN) usually blue (found near left Ctrl key)with one of the numeric keys. So, first make sure your laptop output is correct and then try input key on your projector.
SOURCE: SONY VPL-ES1 DATA PROJECTOR
I have same problem. There is light on power led. 2 hours of standby doesn't work..
SOURCE: Sony VPL CS5 Multimedia Projector Problem
The Temp/fan light is on and is shutting down the projector what do I do
SOURCE: Help with Sony VPL-ES3 Focus problem
ey mann.sorry for my english ok.im from to argentina and i have the some problem with the cover-lamp.i try the six step for try a find a solution,but not working.the lamp try to star two oportunities but put in cover lamp again.you can help me please? thanks.b
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Please dont forget to vote this answer was helpful
Many thanks
