Whirlpool AWM9000 Front Load Washer Logo
A
Anonymous Posted on Nov 16, 2012
Error FH whirpool awo 9561 - Whirlpool AWM9000 Front Load Washer
1 Related Answer
Anonymous
  • 6277 Answers
  • Posted on Aug 17, 2011
SOURCE: Modle AWO 9561 In the second
Whirlpool's 'FH' stands for 'no water inlet'. Presumably the second cycle is rinsing (?) and that requires cold water as opposed to hot for the first (wash) cycle.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
1helpful
Modle AWO 9561 In the second cycle the machine shows F&H error in the display, machine will not carry on. Even when switching off, same error appears.
John C
1helpful
Instruction manual for AWO 9561 Whirlpool Washing Machine
Try RepairClinic.com. They have a good selection of owners and repair manuals.
3helpful
2answers
I need to download user manual of front load washer Model Whirlpool AWO 9561
Water tap closed
The FH code indicates it is not detecting water fill at the flow meter. Since you say that the washer is filling okay, I would check the wiring between the flowmeter and the control board. A common cause of this problem on this machine is the wiring harness jiggling loose. Unplug and reseat the wiring harness and see if it clears up the problem. Also look for and clean out any corrosion build-up where the harness plugs in. Hope this helped and best wishes.
After 27 minutes into wash get an FH error
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
1helpful
Fh
whirpool front load washer f/h is a water fill error, no water supply to unit. be sure to check you valves are on
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
