Volvo S80 04 2004 Logo
peter morgan Posted on Nov 16, 2012
Ignitionswitch will not move into starter posission
Ignition key turns and brings on dashboard and radio etc,but will not turn further to start engine
On a 2005 chevy cobalt 2.2L manual
it's a manual means my transmission is manual transmission?
with a left foot clutch ,the clutch switch is bad above the pedal clutch
that switch enables the starter relay just like all cars, manual
so you an not start engine in gear.
those other problems are other causes.
IMMO key must not be ignored. padlock
thee users guide tells you what the lamp does. (lost that?)
lost the second ignition key? from when car was new.
some cars dim HL lamps to have extra power to crank the engine, a super good features on all cars with it.
you just buy a dead car, or did it just fail out of the blue.??????????
learn what RAP is in the manual.?
key off radio works for delay10mn them or ends door open
page 2-18 in the manual
now IMMO words same manual free, to all chev. owners.
Page 2-15 actual
to start the engine closes door or IMMO Passlock
will fail.
Your vehicle is equipped with the Passlock®
theft-deterrent system.
Passlock®
is a passive theft-deterrent system. Passlock®
enables fuel if the ignition lock cylinder is turned with
a valid key. If a correct key is not used or the ignition
lock cylinder is tampered with, fuel is disabled
During normal operation, the security light will go off
approximately three seconds after the key is turned to
RUN following an engine start.
If the engine stalls and the security light flashes, wait
until the light stops flashing before trying to restart
the engine. Remember to release the key from START
as soon as the engine starts.
If the engine is running and the security light comes on,
you will be able to restart the engine if you turn the
engine off. However, your Passlock®system is not working properly and must be serviced by yourdealer.
READ
https://www.manualowl.com/am/Chevrolet/2005-Cobalt/Manual/388
but the clutch switch is failing and can be jumpered easy, your paper clip. some switches have adjustment or are just fell loose.
Wont heat getting fuel but wont ignite
6 Common Reasons Your Car Won't Start ' General ...
www.genautoinc.com/6-common-reasons-your-car-wont-start.php
Jun 25, 2015 - If no dashboard lights come on when you turn the key in the ignition, that's a ... You can also check whether your windshield wipers, radio, heat/AC or headlights work. ... If your car can't pump the gas to fuel the engine, it won't start. ...the starter works and the fuel gets to the engine, but still nothing happens.
Three Reasons Why Your Car May Not Start
www.dirtcheapquotes.com/Mechanical/why_car_wont_start.htm
Your online resource for auto, truck or motorcycle insurance. ... Starting Problem # 1: Engine Won't Crank At All. Scenario: You turn the key, but nothing happens: And by nothing, we mean there ... Jump-starting the battery should get the engine to start. ... Incars with electronic fuel injection, you should hear a light hum a few ...
Car Won't Start ' The Family Handyman
www.familyhandyman.com > Skills
If you turn the car key and your car won't start, don't give up. Before you call for a tow, try these seven simple tricks to get your car started again. The only tool ... To heat up the battery, terminals and starter, try the "key cycling" trick (photo 1). But if the domelight stayed bright when you turned the key, move on to the next trick.
How to Diagnose Problems If Your Car Won't Start - For ...
2answers
I have mazda 3 hatchback petrol model 2005. The car is giving problem while starting. There is no ignition or click on starting. No response of whatsoever on turning the key to ignittion. All lights /...
since car is starting from pushing i would imagine it could be the starter motor... just a thought. also if thats not the problem maybe a wire has come loose (this isunlikely but possible) hope this helps?
Turning ignition key there is silence....battery is ok as lights, radio come on strong. I keep trying, turning the key and moving gear shift et...and maybe it finally connects and engin fires and starts...
When this happens and the key is in the Ignition position, do the dash lights, etc come on? Could be the ignition switch is bad, and this is and easy way to tell. If the ignition is on and when we go to START, nothing happens, I would replace the starter/solenoid next.
1helpful
4answers
2006 Jeep Wrangler won't start
First, make sure you can turn the engine by hand. If you can't then the starter can't turn it either. Have someone else turn the key and look for the source of the click...may be a relay. Go over the starting circuit with a volt meter. Check for power at the starter main terminal and then with the key turned to "start" check for power at the trigger terminal on the starter. Check battery voltage and check relay operation.
You have a neutral safety switch on the transmission if its an automatic and a clutch switch if it's a stick. Check them as well. Make sure battery grounding on fender and block are also clean and secure.
2helpful
2answers
94 z wont start
You will have to check, at the starter, for power to the SMALL wire on the starter solenoid (which is on the starter) when turning the ignition switch to start.
If there is power to this wire ( usually purple ) and power at the LARGE cable ( from the battery ) at the starter end.....you need a starter.
If you do not have power at the small wire at the solenoid with the key in start position and battery power is OK.....check the safety neutral switch.Moving the shifter around a little can sometimes allow the car to start if the neutral switch is worn.
A new battery does not always mean a fully charged battery.
Try a boost from another car before testing the starter for power.
The battery cables need to be clean and tight....and check the ground to the engine as well.
Everything else may work OK with bad connections,they don't use the power the starter needs to turn the engine over.
1helpful
2answers
2000 Buick Custom - no response on inital start
that sounds like its the ignitionswitch is going bad on the car or its the ignition its self. it could also be a loose wire going to your starter.
1helpful
Mini van wont start
Sounds like starter selanoid, but first make sure battery connections are clean and tight, if sure they are then turn on headlights and try to start if still clicks and lights dim its starter.
1helpful
1998 buick lesabre wont start
Do you have a Chip in the Key? if so that Could be the Problem,Ya see the chip is a resistor and if it looses its ELECTRONIC VALUE in its Case Resistance it wont start to test this Turn the Key in the ON posission then do the Screwdriver thing If it Starts Key is Good and Most Likely the Ignition (SWITCH) is Bad <<ELECTRICAL Side NOY LOCKEST SIDE For More Info Recontact Me
[email protected]<<<<<<<<<<<<<<<
Top Volvo Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Volvo Car Audio and Video Expert? Answer questions, earn points and help others
