Making different noises, during wash cycle it makes a low pitch moaning noise. during the spin cycle it sounds like a whining noise with different pitches. tonight it made a load click noise and stopped as if the motor experienced a over temp and tripped out. after a few minutes I was able to restart the washer.
SOURCE: Washer is making different noises during wash and rinse cycle
What is the model number of the unit?
SOURCE: Maytag MVAT346AWW
Remove the back lower left access panel. You will find the drain pump there. 95% of these problems that you have described is from the drain pump bearing going out. If possible, run the washer with this panel opened and listen to the pump. If the noise you hear is coming from there replace the pump with the new designed pump. Here is the pump to order. To replace the pump, tilt the washer back and remove the belt, then remove the two hoses from the pump and then the three screws that hold the pump on. If the pump is not the problem, post back to me.
