Nintendo Pokemon Crystal Logo
Kyle Kammer Posted on Nov 16, 2012
My pokemon crystal's ingame time doesn't change.
The batter in the cartridge isn't the problem it's new. Me and my friend think it's the control crystal in the game cartridge but I can't find what the clock frequency for the crystal is to change it. If anyone know what the problem actually is or what the clock frequency for the control crystal is your help would be greatly appreciated.
I have the game boy color game Pokemon Crystal version. It works completely fine but one Major Issue. IT DOESN'T SAVE MY PROGRESS. I could save a game. Turn off my game boy & When the game menu...
Lately, many GBC games have hit their age limit. there is a small battery inside each cartridge that allows your game to be saved. follow the instructions below to replace it.
http://www.instructables.com/id/How-To-Replace-A-GBC-Cartridge-Battery/
When i save on Pokemon gold, silver, and crystal (for GBA) then turn if off then back on to load my game it says "the saved file is corrupted" of there is no "continue" button to push....
Well its because the battery inside of the gamepack is dead now. The battery inside of the gamepack allows you to save the game data is dead now so buy a new one then.
  • How To Replace the Save Battery In Pokemon Gold/Silver/Crystal ... 2q== play_c.gif www.youtube.com/watch?v=IJ_h6P1tF7010 min - 16 Apr 2010 - Uploaded by KMCMATT1
    How To Replace the Save Battery In Pokemon Gold/Silver/Crystal ... Warning: Replacing the battery can damage your game cartridge and ...
    More videos for game save replacement batteries pokemon ... »
  • 2helpful
    Pokemon Silver for Game Boy Color: my pokemon silver game for game boy color keeps sa...
    Well its because the battery inside of the gamepack that allows you to save the game data is dead now or its a bad gamepack then.
    Can your Pokemon game still hold a save?
    If your Game Boy game is no longer able to hold a save, yet can still be played fine, that most likely means that the battery in the game cartridge has run out of energy.
    You can easily replace this battery, restoring the cartridge's ability to store save data. This replacement can be performed for much less than the cost of buying a new game. You just need to purchase a new battery.
    **Basic soldering skills required**
    Materials:
    Soldering iron
    New 3 Volt Coin Cell Battery - CR2025 (165mAh) or CR2032 (220mAh)
    Adhesive tape
    Fine tipped hemostat or needle-nosed pliers
    Flip over your cartridge.
    Locate Screw
    Using a hemostat, needle-nosed pliers, or anything else that you can grip it with, unscrew this little screw by turning counter-clockwise.
    Once the screw has been removed, turn cartridge over, slide the front cover downwards, and pull it off.
    Now you can see the circuit board, and the battery that allows one of the chips to retain the game save data.
    You can see that both Pokemon Red and Silver cartridges look very similar, except that the Silver circuit board has a crystal oscillator in the upper left-hand corner to control the passing of time in the game.
    Coming next: Removal and replacement of the battery
    Is there anyway to recover data? I went to play it one day and it no longer has a continue only new game
    No, the only way to stop this problem is to change the battery because it is dying or dead; this is causing the memory erases. What you need to do is take the cartridge and unscrew it and change the battery. Here is a guide to replace it: http://www.instructables.com/id/How-to-replace-the-battery-in-a-pokemon-goldsilve/ If you aren't good with soldering, I would recommend just buy a new Pokemon Crystal game.
    1helpful
    File is corrupted
    Why wont the game save?
    What you need to do is take the cartridge and unscrew it and change the battery. When the battery dies, the file becomes corrupt and erases every time you turn it off and back on. Here is a guide to replace it: http://www.instructables.com/id/How-to-replace-the-battery-in-a-pokemon-goldsilve/ If you aren't good with soldering, I would recommend just buy a new Pokemon Gold game.
    Is there anyway to recover data? I went to play it one day and it no longer has a continue, only new game
    No, the only way to stop this problem is to change the battery because it is dying or dead; this is causing the memory erases. What you need to do is take the cartridge and unscrew it and change the battery. Here is a guide to replace it:http://www.instructables.com/id/How-to-replace-the-battery-in-a-pokemon-goldsilve/If you aren't good with soldering, I would recommend just buy a new Pokemon Crystal game.
    MY GAME STOPPED WORKING AND DOESN'T READS A GAME
    Top Nintendo Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Aron
    Sean Wright
    Sean Wright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
