SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
SOURCE: danby wine cooler repair
I am having a problem with my wine cooler also.I found the upper evap fan not running.So i opened up the control board and plugged the fan that was not working into one of the other 2 sockets,and the fan worked.so i have a circuit board problem.If you go online to sears parts and repair.put in your model# and search,it will bring up a diagram of most of the parts available.And no it doesnt have to be a GE product.
SOURCE: Avanti wine cooler temperature problem
repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area location.
SOURCE: Wine cooler not running. When thermostat was
You have either a week connection or a bad thermostat. Check your connections. Part # 2767-s
SOURCE: MC wine cooler MCWC44DZ error code e3
I had an E3 on the upper zone. This fix was simple. Unscrew the 2 screws for the middle tray. Pull tray out as far as you can. Check the wires in the back, those are the wires for the fans in the back. The connectors over time corrode, and break off... All I did was connected the 2 wires that had broken off of their connector directly to eachother. E3 went away and the cooler is working as it should now.in
