you will need to replace the power supply in the pc , the light on the back of the tower on the power supply indicates that your power lead is working , that is all, the power transformer inside it has blown
You might have heard and searched about shutting down remote PC.But, have you ever wished to turn on your PC remotely and access your file from FTP server and shut it down when not needed? Well you can. Sounds crazy isn’t it?
With simple tweak, you can turn your PC on from LAN. This will be a lot help if you have FTP server enabled from your desktop and you may want to access it from internet occasionally. Turning your PC always on will not be good as it will consume lots of energy. Even more your PC will be much more venerable for uninvited access.
To prevent this remotely turning on your PC can be good alternative.
To turn your PC on, all you need is the MAC (Physical address) address of the PC that you are turning on and Wake up on LAN or Power management from PCI enabled in the BIOS in the PC you want to turn on Remotely.
To check if it is enabled or not, go to BIOS setting in your PC by restarting and pressing Delete key(may varry according to motherboard). Go to Power Management Options, search for Wake up on LAN or Power management from PCI or any similar terms and enable it.
If you don’t see any option to manage power for PCI adapters then it might be possible to do it in Windows mode.
To do this, boot your computer to windows, go to Device Manager. Under network adapter choose the Network card that will be used to connect to LAN, i.e. your ethernet card.
Right click on it and choose properties. Go to Advanced tab.
Now in Property box scroll down to Shutdown Wake up or any similar terms. Select it and Enable it.
You may require a reboot after this.
Now your PC is ready to be turned on from LAN. This will enable to manage power from PCI devices like Ethernet cards. What it actually does is, configures BIOS to turn the PCI Ethernet card to grab some power even if PC is Powered Off. If any computer from LAN sends some command to PCI card then will will power on your PC.
Now anyting left to do is to have a tool to turn your remote PC own from remote location. I often use this tool since its free and customizable. With this free tool you only need to enter IP address of your PC and it will automatically get the MAC address of it. If required you have password field to enter.
Pressing Turn On button will turn on the PC with specified MAC address or IP address.You can also check if the PC is on or off.
Here are some of the steps to you can reboot your pc without using a keyboard:
1) Long press the power button - Press the power button for about 3-5 seconds. If the power LED or power supply fan shuts off, that means you have successfully turn off your pc. Press it again to turn on.
2) Unplug the power cord from the power supply - Force your pc to shutdown by unplugging the power cord from the power supply of your pc. Put it back again and press power button to turn on.
Note: Please make sure you have saved important activities before doing this as this will immediately turn off your pc.
can you be a little more specific as to symptoms? any lights come on? do you get any beeps? are you plugged into a power strip? have you tried a different outlet, or cord? it doesn't turn on is very vague, and doesn't really tell us anything :) please be more specific
POWER OPTION control panel---->power options--->change plan setting---> Turn off the display-never Put the computer to sleep-never control panel---->power options--->change plan setting--->advanced power setting -set hard disk "turn off hard disk after" to never -set Sleep "Sleep after" to never -set hybrid sleep setting to off -set hibernate after setting to never Restart pc POWER OPTION control panel---->power options--->change plan setting---> Turn off the display-never Put the computer to sleep-never control panel---->power options--->change plan setting--->advanced power setting -set hard disk "turn off hard disk after" to never -set Sleep "Sleep after" to never -set hybrid sleep setting to off -set hibernate after setting to never -set display to never Restart pc
Turn off the pc, disconnect the power cord. Remove the battery. Leave it alone for a few minutes. Plug in the power cord (do not replace battery yet) and turn it on. If it works, turn it off, remove power cord and replace battery. Plug power cord back in and turn on pc again.
the monitor is going into power saving mode ... it can happen if it is not receiving any signal from the pc ( pc is not running or booted properly, bad video cable connection monitor to pc) or the pc is itself in suspend/standby mode.
The scanner have two ports to connect to PC, USB and Parallel.
It has no Power switch.
Disconnect all cables from your scanner (USB/Parallel and power.
Plug power cable to the scanner, and then plug the power supply to an outlet.
Does it turn on ?
If not, than check the power adaptor.
If it turns on, then turn off your computer, plug the USB/Paralel connector to the scanner and to your PC and turn on your PC.
You should know that you can use only one connection for your scanner at a time, USB OR Parallel. Parallel for under Windows98, and USB for Win98 and above.
