Question about Just Wireless Bluetooth Headset - BT-38
How do i switch calls using the bt-38k1
How do I switch from one call to the next like call waiting.
I have BT line and have call divert but can't remember how to divert calls, HELP please
Check which services are active [System X] *#001#
Charge advice (before call) *40* (Number)
Charge advice (All calls) *411#
Charge advice (During call) "R"(to hold call) *40#(Call will be reconnected)
Cancel all calls charge advice #411#
Reminder call *55*(Time in 24 hour format)#
Cancel reminder call #55#
Call Divert - all calls - activate *21*(Number to divert to)#
Call Divert - all calls - to check *#21#
Call Divert - all calls - to cancel #21#
Call Divert - on busy - to activate *67*(Number to divert to)#
Call Divert - on busy - to check *#67#
Call Divert - on busy - to cancel #67#
Call Divert - on no reply - to activate *61*(Number to divert to)#
Call Divert - on no reply - to check *#61#
Call Divert - on no reply - to cancel #61#
Call waiting on *43#
Call waiting off #43#
Call waiting - to check condition *#43#
Call waiting - to answer 2nd caller Recall + 2
Call waiting - remove beeps during call Recall + 0
"Ring back" (Camp on busy) 5
Cancel ring back #37#
Caller display on *234#
Caller display off #234#
BT call minder (voice mail) 1571
Check called number 1471
Release CLI 1470 + dialled number
Withhold CLI 141 + dialled number
Access "Choose to refuse" 14258
Call barring on (outgoing) *341 + option number #
(options are 1 = allows 999 and operator, 2 = allows 999 & local, 3 = allows 999 & STD, 4 = bars all operator calls, 5 = bars *, 6 = bars premium adult lines, 7 = bars premium information lines)
Call barring off (outgoing) #341*(PIN code)#
Incoming calls barred off [System X] #261#
Incoming calls barred on *261#
Incoming calls barred off #261*(PIN code)#
Feb 19, 2015 | BT Lands Phones
Bluetooth ear piece pairing
open bluetooth in your mobile
open for all/show to all
switch on earpiece
long press the bt button comes with earpiece
now search for any bt device in your phone once detected
add to your bt list
next time whenever wanted to connect
just switch on bt in mob n ep
and long press the ep bt button
Dec 26, 2013 | Motorola Cell Phones
My iPad won't find my Bluetooth speaker
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
Jan 14, 2013 | Harman Kardon JBL Flip black
Bluetooth indicator is not lit despite I switch the wireless ON
Confirm the phone number where you would like Verizon to call you. We will call you momentarily to connect you to our automated system. You can also call us at 1 (800) VERIZON (1-800-204-4427).
Apr 13, 2017 | Dell Latitude D830 Notebook
Forgot my password for my xv6700
) start phm regedit (google it to find a download location) go to HKEY LOCAL MACHINE>SERVICES>WirelessMGR
2) Edit the key called mutexflag change the value from 1 to 0
3) accept the changes close the program set you phone down and WAIT 15 minutes.
4) reset phone by pushing the reset button on the bottom
Put the phone in Field Test Mode:
From the phone dialpad call ##33284 and then hit send this will turn on the field test program.
Enable Dial up networking over Bluetooth:
Dial ##3328873 and hit send, then check the enable bt dun enable option and reset your phone, you should now be able to configure your PC or laptop to use BT DUN.
Feb 27, 2012 | HTC Verizon XV6700 Cellular Phone
No ringing sound for second incoming call
On the intercom, if it's a TA or similar phone system, dial 7311# for call waiting on outside lines and 7321# for call waiting on the intercom. (0 cancels).
Carl
May 21, 2009 | Panasonic KX-TS3282W Corded Phone
Eu is using Bt voyager 210..power/dsl off ..troubleshoot
if the cmr is using a BT voyger/// first try pwr cycle router/// wait for a min// if tht does not work... do ipconfig// if gettin the default/// reconfig the bt voyger// but i do belive the router maybe faulty//
Sep 12, 2007 | Computers & Internet
Just Wireless Bluetooth Headset - BT-38 Logo
47 people viewed this question
Top Just Wireless Radio Communications Experts
Anthony Ward
Anthony Ward
Don Eagan
Bill Boyd
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
