My modem is plugged directly into the wall in my living room. Whenever someone enters the room, no matter how quickly, slowly, quietly, loudly, jarringly, or softly, the modem's second light labled atm turns off and the light next to it labeled dsl blinks orange. After 30 seconds it fixes itself and the internet returns, but the temporary loss of connection everytime someone enters or leaves the most used room in the house is very, very frustrating. This started happening a week ago. Can you help?
SOURCE: speedstresm 5100 modem
the power light is graan, and ethernet light is green, and the DSL light is green. but the internet and acticity light is not on so i need to upgrade the modem that i hav't used in three years.
SOURCE: Intermitent DSL/Internet Connnectivity 2701 Router
Hii,
* If you can connect after disconnecting power and reconnecting, it means there is formation of static charge on modem
* Check whether there is any cordless phone or any other satellite devices next to the modem. If so, move the modem 10 feet away.
* If your modem is placed on carpet, please place it on wooden desk
For guest:
Do you see the power is also interrupted while loosing connection? If so try plugging the modem into different socket. Dont waste money for simple problems.
If this doesnt work, please dont rate me down, if it works, please rate me as fixya!!! lol...
Have a nice day!!!
SOURCE: Modem won't connect to internet.
maybe you have to wait for your provider for them to isolate the problem, it seems that your modem got hit maybe by high surge. ask them to bring a spare modem for isolation.. there is no way for you to isolate the problem coz you've already done the basic....
SOURCE: 2wire 2701HG-B got red light on power & green light on wireless
Issue that you have mentioned its very common among 2Wire modems. Most of the cases we have diagnosed Modem usually OK but the AC Adapter, AC adapter somehow comes from 3rd party with low quality production. Due to its circuit design internal heat dries up the DC output capacitors. So DC output comes up with ripple and it cause modem to not work properly. You may change the AC adapter or you can change its Capacitors. Same rate AC adapters will work fine. Just make sure polarization is right.
If Issue continues you may post for further diagnosis
Good Luck
SOURCE: Ethernet light flashing
Check your DSL Filters on your house phones or anything connected to the phone line EXCEPT the modem. The modem should not have a filter on it. If this doesnt help I would recommend getting your ISP out to test the line because sometimes the resisitors or hardware in the box goes bad or at the DSLAM.
