SOURCE: 1. After brewing a cup of coffee, when the grinds
HI
Excess water into the drip tray is an indication that you don't have enough coffee going into the brew unit. There is a lever on the top of the door that has a + on one side and a - to the front. Push the lever back to the full plus, then pull it forward 1 click. Try that.
Water into the drip tray is normal in small amounts. This is the release of pressure after brewing, like the 3 way valve on commercial machines
SOURCE: Saeco Royal Digital Not brewing Coffee
If you try to make a cup of coffee, hold the button to see if there will comes some coffee, it can be the memory that have loose the settings. If so you have to program the machine again.
Best regards
/Mirran
SOURCE: The Coffee bean holder
You may have accidentally dropped water into the grinders. Email me your email address and I'll send you grinder cleaning instructions. If the grinder cleaning does not work.. You may have to have to machine serviced. Please include the model of machine and that you would like the grinder cleaning instructions. Email: [email protected]
SOURCE: Saeco Royal Digital won't brew coffee
normaly descale it gonna affect the water . in the waste cointainer do you have coffee that goes there i tink the brewer is the problem the pvc thing inside the machine that can be remove .remove check it visualy something blocking it cheers
I wanted to add that I used a toothpick to try and clear any possible blockages inside of the dispensing head (where the coffee comes drips out from).. and that did not solve the problem. Also, I regularly do my proper maintenance on the machine and I regularly wash out the brew cup.
