OKI C3200n Led Printer Logo
Cheryl Mackin Posted on Nov 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Mac osx 10,8.2. I have just downloaded Mountain Lion from Apple. My Oki printer will not print.
Printer is C3200 Oki laser.
Hans Pedersen
Level 3:
  • Master 3,606 Answers
  • Posted on Nov 16, 2012
Hans Pedersen
Master
Level 3:
Answers
3606
Questions
0
Helped
2231015
Points
8683
Hello try to renew the driver from here:
http://my.okidata.com/pp-C3200n.nsf
Good luck
5 Related Answers
Anonymous
  • 141 Answers
  • Posted on Mar 26, 2008
SOURCE: Oki c5800 laser printer
http://www.c5800.co.uk/index.asp?printername=C5800&menumode=0&content=C5800downloads
At the bottom you will see the file C58uEN1.pdf
Go to page 89
SAROKIDATA
  • Posted on Apr 20, 2008
SOURCE: oki c5200 printer driver for MAC
I also need a driver for my Oki C5200 laser and Mac with OS X Leopard. HELP.
Joed911
JDTec
  • 4338 Answers
  • Posted on Feb 11, 2009
SOURCE: drivers for a C3200 Oki laser printer to go with an Apple MacBook
Here are Mac drivers on this link:
http://my.okidata.com/DSDownWeb.nsf/(MOC-C3200n)?OpenView&Start=1&Count=30&Expand=12
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Geoff
  • 562 Answers
  • Posted on May 07, 2009
SOURCE: How can I reset my Drum Life Counter on my Printer?
http://my.okidata.com/PP-B4250.nsf?opendatabase
Guide Users: B4250 download user manual
American English
Anonymous
  • 22 Answers
  • Posted on Jul 24, 2009
SOURCE: OKI C3200, status monitor
Check our USB cable. It should contain AWG marking on it. Depending on AWG number there is a limit to USB cable length as follows:
28AWG = 0.81 m
26AWG = 1.31 m
24AWG = 2.08 m
22AWG = 3.33 m
20AWG = 5.00 m
Make sure your cable does not exceed the maximum length according to its marking. Replace the cable if it exceeds the length.
How do l download hp laser jet 1018 to mac book air.
The 1018 is not supported by HP with the Mac OS Mountain Lion. I found this on an HP forum and it worked for someone else. You could try this:
Thank you for posting,
Unfortunately, HP laserjet 1018 is not suported in Mac OS X 10.8 Mountain Lion. How evere you can use the builtin drivers that goes along with the operating system and select teh driver of another printer and check.
Connect the printer to the computer and then go to System Preferences and click on Print and Fax. In the Print Fax window, lick on the Plus sign and you will find the printer, please select the printer and then under print using click on the drop down and click on "Select print Software" and in the list, please select HP Laserjet 1015 pr HP Laserjet 1022 and check.
If you don't find these printers in the list, please download and install the latest print driver version 2.12 from the apple web site using the link below.
http://support.apple.com/kb/DL907
After downloading and install the update, please try the steps given above.
Filter Failed
if this printer support Mac operating than u can print from Mac otherwise not possible.
Double side printing HP LaserJet M1120 MFP
Hi Franziska,
HP has not yet released Driver software for your MAC LION however there is a solution for this.
In order to print 2 sided ( duplex printing ) you need to install drivers and it is possible by doing Apple Update.
The link below will give you more details information of how to install the drivers.
MAC LION Driver Update
Once you have done the Update and installed the drivers, you will find the Printer name in Printers list.
Click on Printer Utility and under Layout you will find options to choose 2 sided printing
Regards,
Sean
1helpful
2answers
Cannot find driver/software for my dusty Canon imageCLASS MF3240 on mac OS 10.7 Lion?
There is no driver for your printer to work with OSX. It was for Windows OS only. AND Apple does not support this particular model either.Link below list support printers by Apple OSX>
http://support.apple.com/kb/ht3669
2helpful
2answers
Filter failed
Go to "IP" in the add printer section. It is a "globe" at the top of the page. In address put the address of your printer there and name the printer at the bottom. Worked for me.
2helpful
What are the requirements to download Apple Mountain Lion OSX?
You must have the following computer to download Mountain Lion:
iMac (Mid 2007 or newer)
MacBook (Late 2008 Aluminum, or Early 2009 or newer)
MacBook Pro (Mid/Late 2007 or newer)
MacBook Air (Late 2008 or newer)
Mac mini (Early 2009 or newer)
Mac Pro (Early 2008 or newer)
Xserve (Early 2009)
Once that is done, you must be updated to the most recent version of either Snow Leopard or Lion. If you don't have either of these operating systems (which is highly unlikely considering the other computers should have them, but I digress) then you will need to get them before Mountain Lion.
After that, go to the Apple Store and download Mountain Lion!
Looking for the TDK LPCW 100 Driver for Mac OSX Lion
The printing application requires rosetta so is not supported in lion. As the actual printer is discontinued the two choices are: 1. Get a new printer or 2. Run snow leopard WITHIN Lion using software such as 'Virtual Box'. http://m.zdnet.com/blog/apple/run-virtualized-snow-leopard-and-rosetta-on-lion/10898
2answers
Drivers for a C3200 Oki laser printer to go with an Apple MacBook
Do a google search, there are 3rd party drivers that work all sorts of old and odd stuff, the Oki sounds mainstream, the term is GIMP driver I think
Top OKI Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
