This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at
http://www.vtechsquad.com/ This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
This
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1KThis
Thanks for the suggestion, but unfortunately I've just replaced the cartridges and the problem remains.....
I replaced the cartridges but continue to get error message "put in cartridge"
I have the same problem. Out of the blue, the "wrong cartridge" message came on. The ink was 75% full. I uninstalled the cartridges and cleaned the heads, shut off the computer and also the printer and the problems remain. Shot Canon off a notice and they recommended bringing it in for service. Service = same price of a new purchase.
wrong cartridge
