The EPA logo and the Fullscreen logo all are stored in the bios. That is the update
you download from the manufacturer's website contains both the logos in it. So if you mod the bios update and then apply the patch the next time when you boot your computer you will see the new logo.
***BEWARE A BAD FLASH CAN RENDER YOUR MOTHERBOARD USELESS****
Software Used
Winflash 1.51 : ftp://ftp.ecs.com.tw/driver/bios/flash/winflash151.exe
Award Bios Editor 1.0 : http://sourceforge.net/projects/awdbedit/
CBROM 2.15 : http://www.biosmods.com/download/award/cbrom215.zip
The mods are in two sections. If you only want one or the other, just skip to that section.
FULLSCREEN LOGO
1. Make Sure the motherboard uses the Award Bios.
2. Either Download the new Bios from the Manufacturer website or get it from the system Bios directly by backing it up. For backing up and updating bios, I use WinFlash 1.51 (there might be a newer version, I just stick with what works!).
3. Now we have the bios file on disk. Now make a new bitmap image with any of your favorite imaging software. Make sure that the final bitmap image you have created is 640*480 and 256 colors.
4. Now use the CBROM Utility to change the boot logo in the bios file.
This is done by using Command Prompt
c:\bios>CBROM215 bios.bin /logo logo.bmp
5. Now to check whether the bios file was updated correctly. Run the Award bios editor. (make sure the dlls in the plugin directory are moved to the folder with awbedit.exe)
6. Load the bios.bin in the Award bios editor and check in the left hand list for Fullscreen Logo and that it does show your logo. If okay your bios is now ready to be flashed.
7. Now use Winflash utility, load the bios.bin and click on update .
8. Reboot the computer and the bios logo is changed.
EPA Logo:
Procedure for the EPA logo is just same except the few things.
Image size is : 138*84 16 Colors and 72 pixels/inch
Command for adding to bios file is : c:\bios>CBROM215 bios.bin /epa epalogo.bmp
When you check for the EPA logo in the Award Bios Editor, the colors will not be same as those that you choose but when you flash the bios and reboot, it will show the original colors.
*****PRECAUTIONS*****
Never try to flash bios without a uninterruptible power supply (UPS).
Close all the programs before flashing from Windows.
ALWAYS wait for flash program to notify you for reboot, DO NOT EVER EVER reboot when you think it is ready or taking too long. Mucking up the flash CAN MAKE YOUR MOTHERBOARD GARBAGE!!! You have been warned!!
I hope that this helps,
Ken
Hi ! I want to change my Acer Extensa 4120 (Phoenix v1.18) "ACER" logo , i've already downloaded "phoenix bios editor v2.2" and it opens my rom file but when i want to open splash screen window it makes " Runtime Error 632 (key is not unique in collection)"
what should i do please send me an E-mail and help me "[email protected]"
