<p>Many of the new battery-operated devices such as phones and
MP3 players come with USB cables to charge the battery while the computer.
However, wall chargers for these items are missing, damaged or undelivered. If
so, you can use a USB wall charger, USB cables, adapters and because all have
the same size at the end with these boots are endless. <br />
<p><br />
<p>Generic Battery <br />
<p>1. Buy a USB wall charger. These are available online
through www.amazon.com and www.bixnet.com or a limited number of electronics
stores like Radio Shack or Best Buy. <br />
<p><br />
<p>2. Connect the USB end of cable to the USB wall charger. <br />
<p><br />
<p>3. Connect the charger to the USB cable. Then connect it to
the wall. The machine starts working the green light. <br />
<p><br />
<p>iPod Battery <br />
<p>1. Connect the USB cable to the iPod. Be sure to press the
two ends before inserting it into the iPod. If you do not, you can damage the
pins, once that happens, you will not be able to charge your iPod. <br />
<p><br />
<p>2. Mount the USB wall charger sliding the top in half, for
the manual. <br />
<p><br />
<p>3. Connect the USB cable for both USB wall charger. Plug the
wall charger. The costs start when the lights come back on the iPod screen and
you will see the battery icon fill. You can find this anywhere iPod charger are
supplied. <br />
look at the 6 pins on the phones charge port and see if one is higher than the others (usually on the end). if the pins is too far up the lower half doesnt connect to the charger. If your usb port will charge on via usb "DOCK" then more than likely the charger itself (which is way more simple to fix)
1.) if one of the pins on the phones charge port is pushed up, grab a sewing needle and GENTLY push the pin back into place,
2.) if the charging dock is working and is a usb charger like your wall charger, buy a new wall charger at your local electronics store.
