Unlocking a T-Mobile Android device is pretty easy and straightforward. Through the use of the Mobile Device Unlock App you can now unlock your phone with just one tap. Easy, fast, and convenient - UnlockBase can help you with all your mobile unlock needs.
Just make sure you go through the T-Mobile unlock requirements and policies:
Open Menu
Choose Settings
Choose Applications
Choose Manage Applications
Select the application called "Google Apps"
Select "Clear Data"
After a little while a notification will popup in the status bar prompting you to se up your Google account info
Enter the new Google account information
Reboot the cellphone
Please be aware you will lose info that is usually synched to Gmail such as your contacts and calendar information!
As an alternative to the above procedure consider doing a "factory reset" (not described here).
Go to settings > privacy > Factory reset
that will turn it back to stock info and you will have to see the tutorial again and put in your gmail information
To unlock the Mobile so many method available ....But they leads to Data lose....Unlock code is Best Method..they are safe method...I used the Code to Unlock my mobile,....You can get the unlock code here http://www.theunlockspot.com/htc-g1/rs10wp9/ to Unlock Your Mobile from the Network lock.... You check for your locked Network it's Country also.
No you dont need to buy an unlock code if you simply forgot your password code, all you must do is do a hard reset on the phone. and yes you can use it prepaid or with whatever plan you want, all you do is insert your tmobile sim card, i have a flex account with tmobile and i just inserted the sim card, You dont have to contact tmobile.
Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.Now to wipe the device clean:
Press Alt+L. Press Alt+W for a factory reset. Press the Home and Back keys again for about 25 seconds. The device should then reset again and the hard reset is complete.
Hello, The best solution is to call your carrier and ask for your unlock code "WHICH IS FREE" if you are more then 90 days with them, they usually give you the codewith in 5 - 10 business days. Or you can order one online and get it within 5 - 10 minutes and key inthe code, it takes less then 30 seconds to unlock it yourself. You can get one for $18 from here
